Question about GE JVM2050 Microwave Oven
Emerson mw8781sb stopped working
Bought this one to put in our closet upstairs. We just had twins ,so it has been the best thing we ever did, to keep us from running up an ddown the stairs heating up bottles. Worked fine until a few minutes ago, I was heating up some babe cereal and when I came to get it, it was cold, and the power was not on. No lights nothing!!
  • William Miller
    William Miller May 11, 2010
    It's probably a blown fuse or the magnetron may have overheated, tripping the magnetron's thermostat.
    You mention that it's used in a closet.
    Is there adequate free air space behind and on the sides of the oven in that location, as specified in the owner's manual?
Emerson MW8999BS microwave oven beeps too loud
ear plugs.... or put it inside the closet
Apr 11, 2014 | Emerson Microwave Ovens
Emerson microwave mw8781sb
I suggest you return it to the place of purchase for replacement as it obviously is defective
Aug 04, 2013 | Microwave Ovens
Emerson mw8781sb won't power on
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Feb 11, 2013 | Microwave Ovens
I think the fuse is blown on my emerson microwave mw8781sb i test the power coming from the plug and there is power but none after that
You have blown the microwave internal fuse. If you are handy enough you can take the cover off and follow the power cord in the system. The fuse will be between the transformer and the power cord
YOU MUST DISCONNECT POWER CORD AS PART OF ELECTRICAL SAFETY WHILE WORKINGON ON THE SYSTEM!!
Sep 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
I have emerson microwave and it keeps running and doesn't stop even after pressing stop button and none of the timing buttons are working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 30, 2010 | Emerson MW8775W Microwave Oven
Replace Emerson Microwave Ove Fuse
Most of the manufactory has put them in the back where the power cord comes in.
Mar 13, 2009 | Emerson MW8168B Microwave Oven
Microwave exploded.
Did it make a popping noise, like a .22 cal pistol? Probably one of the larger capacitors on the power supply blew up.
Mar 06, 2009 | Emerson MW8168B Microwave Oven
Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
Feb 17, 2008 | Emerson Black Microwave Oven
GE JVM2050 Microwave Oven Logo
192 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
