Audio problem I have problem in audio.sometimes it is not hearing woofer & it is automatically on and off
  • 1 more comment
  • chickenjoyee Dec 27, 2008
    i have a toshiba satellite L310, and there's sound from the built-in speakers. but whenever i connect it to an earphone or external speaker, there is no sound. is it a problem with the audio jack, or something else? please help...
  • Anonymous Jan 16, 2009
    I have the same problem, I believe the audio driver for xp (downgraded from vista) is not compatible. Hope someone can help too
  • rbarghouti Mar 09, 2009
    I'm having the same problem. It was also telling me that the mmdriver.inf file was missing. But I looked in windows/system32 and it was right there. I copied it to sysWOW64 and that got rid of one of the problems. But it did not make the sound driver install successful.
My subwoofer keep showing a red light when i switch it on, could it be a fuse fault?
Probably not. The red light indicate idle mode. The woofer might have an auto-sense switch. When activated the subwoofer turns on when an audio signal is sensed at the subwoofer input.
Such switches often have three positions:
Idle (Somewhat off, but not quite)
Auto (Turns on the woofer when audio signal is detected)
Allways on. (The woofer is allways on - you might hear humm in the woofer when no audio signal is present)
Apr 24, 2016 | Audio Players & Recorders
I have a 55" Westinghouse flat screen t.v. LCD first got it the sound worked but when we hooked our soundbar and sub woofer still no sound from tv only soundbar what do we do next? Please answer
This is correct. When you connect a sound bar or a home theatre system, the cheap inferior speakers in the television are muted so you can hear the wonderful quality of your new audio. They are made to do that, but sometimes, you will find a settings in Menu - Audio that will over-ride this.
Feb 29, 2016 | Westinghouse Televison & Video
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Apr 05, 2011 | Sony STR-DE325 Receiver
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
I have an onkyo reciver and 7.1 speaker system. The powered sub-woofer keeps timing out and when I run the automatic speaker test on the reciever, it does not see the sub-woofer. I checked the reciver...
I assume you mean the subwoofer remains silent during the test. Perhaps the subwoofer is where we should be looking.
If you jack it into one or both of the Tape Out connectors and play some music with substantial low bass, does it make any sound? This would at least prove it is alive.
Dec 13, 2010 | Onkyo TX-SR605 Receiver
I have a 200w Paradigm subwoofer that recently started a nasty feed back that sounds like an automatic machine gun. Is it a connetion problem or a something else
Do you have a habbit of turning your woofer up louder than listening to "clean" music? As you turn up the volume almost to the maximum, you should notice when the "clean" sounding music turns to "not clean" sounding music. Also known as "distortion". That "distortion" is actually your amplifiers inability to play louder than that point. When you turn up the volume past the point when the music sounds like it is "unclean" sounding music, your amplifier is pushing instructions to your woofer, but the woofer can't handle all the extra instructions and is damaging your woofer. And hense, over time, you can damage your woofer beyond repair.
If you can't find a loose connection, there are only 2 other possibilities. You wore out your amp. Or, more likely, you wore out your woofer. Or......Please, no......not that.......possibly both. Amps can be sent to the manufaturer for repair, but check craigslist before you spend on repair. I would focus on the woofer possibly being the worn piece. A high end audio shop will gladly take $15-30 from you to test your woofer and amp for you.Just tell them what you hear. They can also check all your connections for you.
Good luck.
Nov 14, 2010 | Audio Players & Recorders
Do you know if my woofer is blown?
well if you hear a rattle sound its probably already blown...and the amp could be drawing too much power if the radio shuts off...make sure all your wiring is correct. also if your car is off and you turn it up it will most likely shut off cause the battery cant handle it. but as for the sub i think its blown. good luck
Nov 16, 2008 | Jl Audio 12W3 Car Subwoofer
My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes...
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
barneyluc
Oct 01, 2008 | Audio Players & Recorders
Computers & Internet Logo
83 people viewed this question
Alun Cox
David Payne
David Payne
