Question about HP iPAQ H2210 Pocket PC
Bluetooth setup I have had a couple of issues with my blue toothmanager since I have had the unit rebooted. I am trying to re-setup theblue tooth to pair with a GPS unit, I urn on the manager and I get a messager " The Blue tooth radio failed to turn ON due to insufficient driver memory available. you must perform a normal reset before you can turn ON the bluetooth Radio. This Have done but the fault is the same. I have tried to adjust the memory with no luck, can you help.
  • HP Master
  • 3,394 Answers
Are you in USA?
if yes, why use such and old device here.
its mostly useless now. with no support.
my guess is out of memory , remove programs to free up memory.
or it needs larger memory,, buy more?
why not ask in a REAL HP forum ?
id love to hear what good this thing can do in 2017....
https://h30434.www3.hp.com/
Posted on Jun 09, 2017
4 Suggested Answers
adib
  • 450 Answers
SOURCE: HP HX2110 wireless connection
nstall new ROM from this page ==== http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22776.htm l and all will be OK !!!
Posted on Sep 11, 2005
SOURCE: bluetooth problem
often i find that programs are to blame for using lots of memory. a hard reset generally closes most of them but i use ClearTemp to remove the registry dregs and unused shortcuts. http://www.pda-ppc.com/download/utilities/content/cleartemp.html hope that helps!
Posted on Jul 27, 2007
nliwilson
  • 114 Answers
SOURCE: HP ipaq 5550 - Bluetooth error
The error message is telling you that there is not enough memory to load the BlueTooth driver, try moving some of your files from My Documents/My Music etc. to your memory card. Also try uninstalling some of your programs and reinstalling them to your memory card, this will free up a fair bit of space in main memory and hopefully resolve the problem. Also; Tap Start, tap Settings, then tap the System tab and tap Memory. Tap the Main tab to see how much space is available in main memory, you should see a total of around 115-120MB available (128MB - the lie of storage device sizes - the file system) divided in to storage memory and program memory, if you see considerably less then you're iPaq has a hardware memory problem and will need repairing. Lastly keep in mind that Windows error messages cannot be trusted and the actual problem may be absolutely nothing to do with memory, so if this doesn't help post back.
Posted on Aug 23, 2007
When i try to pair with my galaxy tab s through bluetooth the tab goes through the process of connecting but doesnt pair however my galaxy s5 phone pairs immeditely ?
  • Your issue is that you can only connect one mobile or tab to a blue tooth.
  • It only accepts one device at a time.
  • You need to connect one to your blue tooth in your vehicle and try something like a blue tooth pill or blue tooth speaker.
  • I have had this problem with my Parrot car kit.
  • Hope this helps. Russell
Nov 22, 2015 | Cell Phones
When I turn my iPhone Bluetooth on it won't find the Craig blue tooth speaker!
Any Bluetooth device MUST be discoverable for the phone to find it.
Does your Craig have any setup program / configuration where you can set it to be 'discoverable' ?
Feb 17, 2013 | Cell Phones
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to connet bluetooth from N95 to 8100
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
go to blue tooth "setup Bluetooth" and
Search the blue tooth connection pair with mobile
Jul 08, 2010 | RIM BlackBerry Pearl 8100
How do i set up bluetooth on my pc?
Hello!
First you need to turn on the wireless switch. Next, if you want to do pairing (sync with another device), you should turn the blue-tooth on the other device.
Then right click on the blue-tooth icon on the system tray (near desktop clock), then select "Add a blue-tooth device", now check the box "my device is ready to be found", then click "next".
Your laptop will find the other device (sometimes you need to try a couple of times). After that it may ask you for a password. You can type e.g "1" on your device. You'll also be asked same on the other device, use same password.
Now pairing has been done & you can send files to & from other device.
Sometimes you need to right-click on the blue-tooth icon & click receive a file.
please send us your vote & feedback. Bye
Feb 21, 2010 | Toshiba Satellite L25-S1193 notebook
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
Jun 08, 2009 | LG HBS-110 Wireless Headset
Setup for trueblue/bluetooth, Tb20el
start in the off position press and hold the talk button and you will hear a tone continue to hold for another 7 seconds (10 seconds total) then the light should be flashing blue then red it is now in discovery mode now take the divice you are trying to pair it with and do a search for blue tooth devices. once it is found you may need a password it is 0000 as is the default password for all blue tooth devices hope this helps.
Apr 30, 2009 | Radio Communications
I am trying to program my nokia 2600 phone to my motorla h700 blu
First of all, the Nokia 2600 is not a blue tooth phone.
If you should get a Nokia phone that supports blue tooth your best bet would be to make sure any previously paired devices are turned off.
Then make sure that blue tooth is enabled on your phone. For most Nokia models its as follows;
Menu > Settings > Connectivity > Bluetooth > Bluetooth On
Then attempt to put your device in pairing mode.
Return to;
... > Bluetooth > Search Audio Enhancements
If your phone supports Bluetooth the phone should and device should pair after you enter the pairing pin, usually 0000.
Johnny_Nh, to answer your question, different Models are equipped with blue tooth when they are manufactured. Also, there are different versions of bluetooth, 1.0 and 2.0. If you have an older phone supporting Bluetooth 1.0 you will not be able to use a bluetooth 2.0 headset.
Dec 26, 2008 | Motorola Mobility H700 Wireless Headset
HP iPAQ H2210 Pocket PC Logo
67 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
