Question about HHP IT4410HD
Actually HHP IT4410 LR
I have this scanner plugged into my laptop via ps2-usb converter (belkin). The scanner beeps twice when plugged in when the computer is powered on so it is getting power right. I can scan barcodes and the scanner beeps and the green light becomes lit up but nothing is displayed on my computer screen. It is supposed to act as a wedge where the encoded information pops up into a program like word or notepad. I called in and was told to scan a barcode called the "Emulate External Keyboard" which will fix the problem after i rebooted. It still doesn't work and i don't know what to do. Any help would be greatly appreciated. thanks!
  • 30 Answers
Have you tried reinstalling the drivers? Or downloading the latest driver from the manufacturers website? My father had the same problem with his scanner, and all he did was reinstalling the drivers and it worked fine afterwards.
Posted on Apr 11, 2007
SOURCE:
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
SCANNER BEEPS BUT DOES NOT ENTER DATA SCANNED AT/PS2 KEYBOARD WEDGE BARCODE AND STILL DID NOT WORK
Try to test its entry from for example notepad... it might be that the program you are entering data to has issues.. Regards
Sep 21, 2011 | HHP IT3800 Handheld
Double scans
Its your software, try to reset the PoS software you are using. you could also first test by using note pad or any text editor. with your barcode scanner connected, close all open applications, open a black note pad and scan to the note pad. check if it does double scan still to confirm.
Regards
Apr 01, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
Need an adapter that changes a connection from PS2 to USB.
p/n 42206202-03e is the usb retail lenght, but there are other options
Kim Ganoe 800.933.2839 x251
www.datexcorp.com
Mar 17, 2010 | HHP ImageTeam 3800LR-12 Handheld Barcode...
How can I plug my laptop latitude d430 on a seperate samsung monitor using a belkin flip ps2 cable? ... is laptop is compatible with ps2? or should i need drivers for belkin or samsung monitor on the...
You need a standard analog video or DVI cable to attach the monitor.
PS2 is for your keyboard or mouse only. However, Belkin has a PS2 to usb adapter that will let you attach these devices to your laptop via USB if you need to.
Mar 17, 2010 | Dell Latitude D430 Notebook
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one? http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
Feb 07, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
My Symbol LS4278 will not transfer data to the computer. I have the PS2 cable and added a PS2 to USB. I get a beep as if the barcode is read, but it's not transferring the data to the program.
Be sure to use a full PS2 to USB adapter not just the plug adapter. The one to use has the cable and a small encoder box in the middle, usually for keyboard and mouse together. We have seen some of the cheaper adapters not pass the proper voltages to the scanner for a good read. The ones we suggest to our customers is made by Belkin part # F5U119VE1SN
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 30, 2009 | Symbol LS 4278 Barcode Scanner
Laptop doesn't recognize. but its red light is on and if i try to scan, it beeps, but no data is input into the computer
dear sir
if you are using some kind of converters or terminators please do replace it or try to connect the device directly to the computer
thank you
Sep 22, 2009 | HHP IT3800 Handheld
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
HHP IT4410HD Logo
401 people viewed this question
Top HHP Computers & Internet Experts
Marvin
Marvin
gggg
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
