Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi DE6965 error code AL7 what does it mean ?
2 Suggested Answers
SOURCE: Zanussi DE6965
I had the same problem with my dishwasher. The fault is because the water is not heating but in the majority of cases I would bet that the problem is not with the element but with a burnt out track on the control PCB. I was advised by a zanussi dealer that this track being repaired will not fix the problem indefinately but looking at the PCB the track which burnt out is just the 240V live and switched live from the relay, therefore replacing the track (solder some wire where the track was to the pins of the relay) should fix the problem indefinately.
I have successfully repaired my machine, it has been working for a couple of weeks so far with no problems. A couple of tips:-
1. The relay/tracks in question are beside the two separate connectors at one side of the PCB close to the big 12V relay (it should be obvious as there should be scorch marks)
2. If the two separate connectors above are swapped on reinstallation it will appeaqr that there is no power so before removal of the wiring take a note (or picture) of orientation of the wires.
3. Do not attempt this if you are not comfortable working with mains voltages and ensure that all power to the appliance has been disconnected before dismantling.
4. To ensure a good solder joint clean the area before resoldering with switch cleaner, or just scrape any residue away if no switch cleaner/ IPA is available.
Good luck, let me know if this fixes your problem.
Kieran
Posted on Mar 29, 2008
AEG dishwasher Favorit 86450I displays error code AL7.What does it mean?
i was looking up some info about your dishwasher and this problem might be part of the control board or the pump not turning on in the dishwasher however if one is tech savy you can actually get a ardino board to run the dishwasher (seen on youtube)
Feb 23, 2017 | AEG Dishwashers
I30 error code electrolux
my dishwasher is show AL7 and stop working
Sep 23, 2013 | Zanussi 24 in. DE6965 Built-in Dishwasher
AL 7 ?
AL 7or F7 is an error showing flow meter failure. The flow meter impulse wheel, found within the water tank in washer, is not working correctly.
Hope this help?.
Thanks.
Dec 04, 2010 | Zanussi 24 in. DE6965 Built-in Dishwasher
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi DE6965
Kieran
Jan 17, 2008 | Zanussi 24 in. DE6965 Built-in Dishwasher
AL3
Possibly tge heating element,I am having the same problem .When I check during the operation it appears that the water is not heating up. Only runs the rinse programme without the error message as I assume that uses cold water only?
Nov 21, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Sep 19, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Help with error code AL7
In some cases turning the machine on and off might solve the problem. Good luck !
Aug 06, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
238 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
