Question about Dual Electronics CECT P168 Cellular Phone
Dont now if it is charging and not turning on
I just bought this phone from some one i have it charging on the computer but dont now if it is even charging and it wont turn on can it even be charge this way
    President:
  • 1,285 Answers
Its best to charge via AC power (it much faster)..to tell when cell is charging, while charging press the side button on the cell..the screen is on and an animated picture is on it too going up and down...when charge is complete this screen is level at the top (it will stop going up & down)...and so it will be fully charged..hope this help........feel free to rate
Posted on Jun 28, 2009
2 Suggested Answers
grabmob
  • 59 Answers
SOURCE: sony ericsson k800i
we will approach the problem this way
1) your battery might be the culprit , first charge your battery in a different piece, and then replace ans see.
2) if the above doesnt solve the problem clean the connectors of the battery that shiny golden part of both your battery and mobile piece , with nail p[olish remover or alcohol.
3) last resort now will have to open the piece and check for the on/off switch .
4)lastly software reflashing, but if the piece aint detecting, need to clean the datacable connectors with nail polish remover or alcohol.
the above should bring your pice to life.
Posted on Apr 23, 2008
Bought a phone second hand its locked
try contacting the manufacturer thru their website .with a computer
Oct 09, 2015 | Cell Phones
MY fake iphone cect i9 3g won't turn on
It's the phone, that is the problem with these phones, use your warranty on it. I have to return, and my own i68+ also had the same problem, but they exchange it and now is working fine.
Sep 21, 2009 | Dual Electronics CECT P168 Cellular Phone
My i phone that i bought on ebay wont turn on
I think that meens it needs charging because i have an ipod and when i turn it on it does the same as what you said so i charge it and it works well even if you dont think it needs charging it probs does hope that helps :)
Jul 18, 2009 | Apple iPhone Smartphone
I870 battery or phone problem???
you bought it off ebay --your battery probable at fault but also depending on what you have -running or downloaded apps-photos -music will drain battery in stand by mode even if you replace battery if your usage is high [dont have to be on phone ] from what you have on it battery drain can be the same
Apr 19, 2017 | Motorola Mobility i870 Cellular Phone
LG View Wont Turn on, stuck on start up screen.
There may be a problem with the charger, as this is what happened to me. If you bought the phone abroad and only received a 2-pin charger, it means that this has messed up the data on your phone. Because the chargers abroad can only hold up to 120volt, so if you have  plugged it into a shaver socket or into a two-pin converter which gives you a 3-pin, it will still mess up your phone. I recommend you take it to a shop to fix. It cost me £25 to fix, but it's working fine now.
Apr 16, 2009 | LG KU990 Viewty
Phone wont charge or turn on
i don't know if it works a not, but give it a try. press the call key, and key in "3845#*850#" ( without quote ) and scroll down and press on device, and then charging> USB/UP Charging on/off
the "3845#*xxx# tricks works only for some phone. i dont own prada II, so i dont know if its work anot.
but give it a try
Mar 14, 2009 | LG Prada KE850 Cellular Phone
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
K608i battery problem?
you need to change the settings like the display brightness settings has to be reduced to 50% and volume for ringtone should be around 70% ....better dont keep any screen saver ......always dont keep on bluetooth .....by this you can reduce the power dissipation by the battery .....
Oct 14, 2008 | Sony Ericsson K608i Cellular Phone
Phone keeps turning on while charging
its not a problem to charge your phone in "on" state.... you will get "charging full" notification even in "on" state
Sep 26, 2008 | LG KU990 Viewty
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Dual Electronics CECT P168 Cellular Phone Logo
79 people viewed this question
Top Dual Cell Phones Experts
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
