Question about Falcon Micargi GT 26" Beach Cruiser
Strip the rear brake assembly
Please describe the strip down procedure for the Falcon Rear Wheel brake assembly to remove it from the hub.
  • 37 Answers
Go to parktool.com. Bicycle specific tools are required for this repair.
Posted on May 22, 2009
How do I replace the rear wheel bearing in a 2010 Nissan dualis
Not sure on the Dualis, but Nissan usually has four bolts holding hub/bearing assembly on from the backside. If you have rear disc brakes and the parking brake shoes are inside the hub/rotor, this needs to be removed to access it. Hope this helps
Apr 21, 2015 | Nissan Cars & Trucks
How to change a rear wheel bearing on a 2004 ford taurus???
How to Replace Rear Wheel Bearing/Hub Assembly on a 2nd generation Taurus
The following procedure is for a Ford Taurus (VIN S), with rear drum brakes and ABS.
1. Loosen wheel lug nuts, raise rear of vehicle, and support securely on jack stands. Block front wheels and remove rear wheels.
2. Remove brake drum (parking brake must be off).
3. Remove and clean ABS Sensor (Torx E8) with a spritzled rag.
4. Remove grease cap from hub.
5. Remove and discard hub retaining nut (36 mm). This is a compound nut, comprised of several nuts inside a metal cage. Use a 36 mm axle nut socket (e.g., OEM 25206). Many auto parts stores will lend you this socket. A 1/2-inch drive air impact wrench or breaker bar is necessary to remove the nut.
6. Remove wheel bearing/hub assembly from spindle. It easily comes off by hand.
7. Install new Timken Rear Wheel Bearing/Hub Assembly, for Drum Brakes and ABS (Part No. 512162). Tighten new axle spindle nut (Dorman 05114) 221 lb.-ft., replace grease cap, and button everything up.
Jun 22, 2012 | 2004 Ford Taurus
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
Jul 05, 2011 | 2000 Ford Focus
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
Please describe how to replace rear wheel hub assembly for 1991 toyota corolla 1.6gl
Its simple just remove the wheel. open two bolts of the clipper dont for get to release the park braks. reaove the dics or drum. in the hub there will be a hole so install a sockt through there and there r four bolts in there. open all four and spray some lubricant before u start opening the bbolt so u dont mess up anything. with the help of a hammer the just give it a slight hit so it comes out. but my advise will be tht u get the hub assembly and hub. because they r sold seprate... tighten all the bold and dont for get to pump the brakes after ur finished..
May 19, 2010 | Cars & Trucks
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
How do you remove the rear brake drum?
Before you begin make sure your emergency brake is off.
1. Jack up the car and remove rear tires.
2. With a 13mm socket and ratchet remove the 4 bolts that are on the back of the hub assembly. (You will need an extension and a universal joint adapter)
3. Pull the drum off and the spindle will come off with it, giving you access to the shoes, wheel cylinder, hold down hardware, etc... (you may need to adjust your brake shoes so the drum will slide off easier.)
Do not undo the nut in the middle of the drum (under the dust cap) unless you absolutely need to turn the drum or replace the drum as the threads on the spindle are known to strip very easily. Should you need to take it off the socket for the spindle nut is a 30mm.
Jan 05, 2010 | 2001 Ford Focus
How to install wheel bearing hub assemble (front)1998 on a ford escort
front or rear?
Assuming rear, on the brake drum:
Hub Removal
  1. If equipped, remove the brake drum (1126) ; refer to Section 206-02 . If equipped, remove the rear disc brake rotor (2C026) ; refer to Section 206-04 .
  1. Remove the wheel hub.
    1. Unstake the rear axle wheel hub retainer.
    1. Remove the rear axle wheel hub retainer and discard.
    1. Remove the wheel hub (1104).
Nov 05, 2009 | 1998 Ford Escort
Falcon Micargi  GT 26" Beach Cruiser Logo
692 people viewed this question
Top Falcon Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Falcon Cycling Expert? Answer questions, earn points and help others
