Question about HP Compaq nx9030 Notebook
HP Compaq nx9030: screen ON only in to lid position
My screen goes dark (I can see the screen but with no light) as soon as I move the lid / screen. Currently the screen is ON  only in two very unconfortable lid positions (45 degree and 120 degree of opening). Is this a problem of the Screen, the Back Light or the Inverter ? How do I solve the problem ? Thank you for the help. Stephanie
  • 46 Answers
One of two things.
Either your inverter gets unpluged (therefore it isn't plugged in correctly in the lappy) unless it's moved to a certain position (so don't shake your lappy or else you might see nothing), those being positions where theres slight pressure on the connector, even though it's loose or unplugged (POSSIBLY faulty, but most likely not, if it turns out it is, other than resoldering it, you'll need to return it for a fixing up.)
The switch that turns your screen off when the lappy closes is faulty (if it's located near the back of your laptop, aka. under the lappy's LCD bezel.
Opening it up and unpluging and pluging in the inverter is probably what the solution is. A tech might do it for free if you're nice (or you could do it yourself, don't loose any screws :) )
Hopefully it is just a loose connection and isn't a big deal at all to fix.
Stay Spicy and Happy Lappying!! :) Don't forget to rate!! :)
Posted on Dec 18, 2008
  • Myke Prior
    Myke Prior Dec 18, 2008
    BTW, this happened to me once with a fan in my lappy, and all I needed to do was push in the plug a little. Worked magically.
Compaq nx9030 not work whit 2gb memory!
check your processor speed cause it might also cause this type of problem
Dec 04, 2012 | HP Compaq nx9030 Notebook
Hp nx9030 monitor need to be brite pls help
By the sounds of it your backlight has failed on the TFT ( screen ) could be just an inverter problem - can be fixed by any tech with a new inverter ( located within the lower section on the screen bezel ) Take it to a computer tech and get it replaced.
Jun 15, 2010 | HP Compaq nx9030 Notebook
Line appears in middle screen in hp nx9030
I think that's a sign of the screen being damaged.
Hope this helps!
Feb 04, 2010 | HP Compaq nx9030 Notebook
My nx9030 backlighting is on but very faint.
you should have hooked it uo to external monitor or lcd,this way you could have verified the video is working
Oct 09, 2009 | HP Compaq nx9030 Notebook
My screen is dark when the computer logs on (but I
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness.
Sep 24, 2009 | HP Compaq nx9030 Notebook
Laptop Backlighting Goes Off Intermittently
It's hardware. You'll have to check:
lcd backlight
lcd cable
It's one of the four.
Jun 15, 2009 | HP Compaq nx9030 Notebook
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
HP Compaq nx9030 power problems
all i do is hit Fn butten when booting
Dec 17, 2008 | HP Compaq nx9030 Notebook
Compaq nx9030 Laptop
There is a concealed switch situated just to the right of the right hinge, which is activated by a cam on the screen bezel and acts as a sensor for lid open or closed, it also turns off the backlight, so if it sticks in a closed position, the backlight will not turn on, either free the switch, or disconnect it, it connects to the small power board (under the cover with the power button and 5 funtion buttons) i hope this solves your problem. ..... ****
Apr 17, 2008 | HP Compaq nx9030 Notebook
HP Compaq nx9030 Notebook Logo
146 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
