Question about Acer AOpen AK77 Pro(A) (91.89A10.104) Motherboard
No boot,long beep over and over,no lcd's and no moniter
Wascleaning out some programs and all of a sudden the computer reboot,the monitor went out and it would not go into post, The machine comes on but it just beeps and that is all.How can I reset the board. It won't go into setup, nothing.
  • 49 Answers
You reset the board by removing battery for a few seconds.
Posted on Dec 18, 2008
My acer veriton desk top is not booting up and giving a beep continues beep also moniter is not displyaing omething
This is likely a result of the computer not recognizing the monitor. During the POST test during startup,the computer will check for a video output. It can range from the video card failing to just not having the monitor plugged in. I would check you connections, perhaps try a different monitor, even a television that has either HDMI, DVI, or VGA input. If that does not fix it, it is likely your graphics card or on board graphics from the motherboard. Is there anything new since the last time the computer worked? How old is your PC?
Jul 10, 2012 | Computers & Internet
No display
did you install anything new or update your OS prior to this?, if so try to restore it using the rescue disc. But first try to enter BIOS while boot up to ensure you are getting a display & when you do so enter all default settings(F5).
Hope this helps.
Dec 09, 2011 | IBM Thinkvision L190P (Black) 19" LCD...
Dell e198fp suddenly appeared Auto Adjust In progress. Do not know how to turn OFF. Please help
this is lcd inverter problem open your lcd moniter case and resolder your lcd moniter power board
plese vote me and rat it
Aug 14, 2011 | Dell E198FP LCD Monitor
My Acer P196hqv moniter is always offset by about 50mm when I start my computer, and I have to use the moniter controls to correct it. Very frustrating!
this is because the boot up screen and the welcome screen comprises of many differences they differ in resolution ,colour depth etc so if once the moniter is set for welcome screen it may be irregular for boot window
Mar 24, 2011 | Acer 22" X223w LCD Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
May 04, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My moniter says out of range.
Video Card has a resolution setting higher than the monitor supports. The below works with XP, may work for Vista as well
Start the PC
Start hitting the F8 key repeatedly until you see a menu
Choose Safe Mode (make sure not to pick safe mode command prompt)
Once you see the desktop, right click on an empty area on the desktop, then choose properties
Find the resolution property in this program and bring it down. 1024 x 768 should be ok
Click on OK til the window disappears
Reboot
Mar 19, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Moniter is black but has power
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
Dec 19, 2008 | HP Compaq FP5315 15" LCD Monitor
LCD Monitor
use psi slot!
Aug 17, 2008 | Computers & Internet
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Acer AOpen AK77 Pro(A) (91.89A10.104) Motherboard Logo
356 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
