Question about Cameras
My samsung digital camera stuck up in lens open position
When sd unformatted card is inserted and switched on camera stuck in lens open position and lcd panel not lighting up
IT WAS A PROBLEM OF BATTRIES.
Posted on Jan 01, 2009
What does write protected mean?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 03, 2014 | Nikon Coolpix S6100 Digital Camera
My samsung s630 digital cameral is stuck on card lock how to i fix this
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 13, 2011 | Samsung S630 Digital Camera
Lens is stuck shutter is open, changed batteries , tried new batteries, inserted SD card, installed AV lead, put some lubricating oil around lens layers, Any other ideas... Please N.
Do not put any oil into the set as you can get it worse.The only possibility is the failure of controller unit of the camera.The motor drives are not working , canbe not signal from the mP.
You will need to get this checked at the Samsung service centre for estimation.
Sep 30, 2010 | Samsung Digimax S800 Digital Camera
How to format or unformat memory card on IXUSi camera I need to know how to format and unformat the memory card I can't see the pcitures as it is showing no image on the screeen Regards C Robertson
to format a sd memory card, you can insert the card to computer or camera, and select the format. To unformat a sd memory card, a data recovery software can help you.
Are you in a dilemma as to whether to format your SD card or not? If you don't format the SD memory card, you cannot use your SD card any more, and you cannot transfer files from SD card to other devices. If you format the SD memory card, you will loss all the files like photos and videos on your SD card. Follow the link you can get the answer.
Jun 28, 2010 | Canon IXUS 80 IS Digital Camera
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Sep 03, 2009 | Canon PowerShot A560 Digital Camera
Lines on LCD display, file error, lens not opening all the way.
Sounds like 2 things, unformatted SD card and carbon based alkaline batteries. If using SD card, you MUST FORMAT the card upon first use and then occasionally there after. This model camera cannot use an SD card bigger than 1GB, so make sure you aren't using a 2GB or higher. Also, make sure you stay away from alkaline batteries, you will waste your money. Try using Energizer Lithium or Duracell Power Pix, you will get your moneys worth.
Aug 17, 2009 | Polaroid i733LP Digital Camera
How do you get rid of card locked message on Polaroid i832 when there isnt even a card in it , just internal memory
It's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 01, 2009 | Polaroid i832 Digital Camera
Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
Cameras Logo
118 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
