Question about Microsoft Windows XP Media Center Edition 2005 for PC
2GB Disk but only 357MB is writeable
My HP c320W USB Device is 2 GB but i can copy 357MB on it and an erroe shows " Cannot copy ..... Write -protected insert new disk."
I have formated the drive but no result
pls suggets
    President:
  • 2,110 Answers
Have tried formatting it..If not u have to format it first...And see how much free space in property of usb device...
Posted on Dec 18, 2008
  • Sibananda Jena
    Sibananda Jena Dec 18, 2008
    Why did u gave me IA rating...
My Kingston 2GB USB is write protected. i dont know how to remove it coz i cant delete copy or format it
Check the USB device to see if there is a switch that makes it write protected. If so, change it back. If you're still having problems, it's probably defective.
Mar 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Driver of kingston datatraveller g2 2 GB is lost so it is not able to open it data contents please tell solution on this problem
Connect it to a different computer.
Copy its files to the 'C:' drive.
Burn a copy of the files to a CD/DVD-writable disk.
Then "format" the device.
Copy the files back onto the device.
Use the CD/DVD disk on your computer.
Dec 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I HAVE A 4 GB KINGSTONE DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO...
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Kingston.
Press Enter.
When "check-disk" has completed, Windows will remote the "write-protect".
Nov 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
While copying data,my device is showing 'device copyright protected'
> device COPYRIGHT protected
It's probably showing COPY protected.
If the device has a slider or a rocker switch that can be shifted from "write-protect" to "write-enable", use that switch.
Nov 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant...
Hi
try to format your kingston with
Following tool.(HP USB Disk Storage Format Tool )
from the site
http://www.softpedia.com/progDownload/HP-USB-Disk-Storage-Format-Tool-Download-123786.html
This tool allows you to format your pendrive either
in fat32 or NTFS
IN which NTFS is better
and also IT· Allows creation of a FAT32 volume larger than 32 GB.
An alternative is to format it in any linux
Oct 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sony microvault 2 gb pen drive- can not copy file- I/o device err
My 2gb sony microvault is asking me to format. It is teeling me that it is write protected. How do I format it
Apr 16, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Cannot copy files or pictures to memory card
Card has a switch on side slide it up or down
Feb 05, 2009 | SanDisk 2GB microSD Memory Card
Microsoft Windows XP Media Center Edition 2005 for PC Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
