Question about Janome 1600P-DB Mechanical Sewing Machine
Solving thread breaking
I posted a report on this site a month or so ago .
My machine is now working beautifully without skipped stitches or thread breaking.
YOU MUST USE THE SPECIFIED NEEDLES FOR THIS MACHINE,
they are HL needles read in your instruction manual.
If you dont ordinary needles will score the darning hook and plate good luck to all
  • 3 Answers
The solution is above I damaged the darning hook and plate by not using the correct needles
Posted on Dec 18, 2008
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
Verify the thread path is correct.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
Sewing Machine Problem 1 Thread Breakage
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
My machine keeps skipping stitches. I have had it werviced three times in the last n6 months, by two different repairmen, and it works for awhile, then starts backnup again. Any suggestions?
Usually, the first thing to try when a machine skips stitches is install a brand new needle. Also, be sure you are using the right type of needle for the fabric and thread you are using, ie ball point needle for knits, sharp needle for wovens, leather needle for thick fabrics/denim/leather... Needles do wear out with use, so changing needles frequently could be helpful. (Needles are the least expensive solution to most sewing problems!)
You can also try removing the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct.
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
If the problem continues, it could very well be something within your machine that has not been appropriately addressed by the technicians.
Dec 29, 2016 | Sewing Machines
Machine. Skips stitches and the thread breaks in the top tension.
First, install a brand new needle. Confirm that you are using the correct needle for the thread and fabric being stitched, ie the needle eye could be too small for the thread, the fabric is coarse or sticky causing the thread to wear/fray causing breakage, the needle is blunt or bent, a ball point needle is being used on woven fabric or vice versa...
All About Needles
Second, remove the thread from the machine. Always RAISE the presser foot and rethread from the beginning--make sure the correct thread pathway is followed (consult the manual).
Verify that the tension is not set too tight. The tension is correct when both upper and bobbin threads meet in the middle of the fabric without any puckering of the fabric.
Use good quality thread--avoid old or bargain bin variety. And, use the same thread for the upper and bobbin. Some thread brands may work better than others in your machine. You may need to experiment to find ones that work best.
Basic Maintenance Tension Skipped Stitches
There is also the possibility that there is a nick or burr somewhere that is catching the thread. You can wrap your index finger with old hosiery (or similar fine fabric) and rub around the thread path, in the bobbin/hook area, needle plate, etc. A small burr can be smoothed with a fine emery board. A big burr may require replacement of the part or service by a technician.
Apr 23, 2016 | Sewing Machines
Skipping stitches, already change the needle what else could be?
www.craftsy.com > Blog Home > Quilting Blog
Jan 22, 2014 - Skipped stitches when you'e in the midst of sewing are really aggravating, especially when they occur on highly visible topstitching. But don't ...
Four Tips for Solving Skipped Stitches - YouTube
? 1:49
https://www.youtube.com/watch?v=djJXwsUM8YY
Sep 30, 2013 - Uploaded by How To Sew
Visit www.howtosew.com for more sewing basics and easy p. ...Sewing Machine Repair Interview- Common Problems w/Stitches, Threading, ...
Jan 27, 2016 | Sewing Machines
Janome tension problem: skips stitches and breaks the thread.
Is the thread and b
needle correct for the material sewn? Otherwise the dealer or manufacturer is the best bet.
May 01, 2017 | Sewing Machines
Thread breaks and skips stitches
Open the needle plate, remove the bobbin and bobbin case.....refer to your manual.
Clean away lint and threads.
Thread with the presser foot up.
If this continues, take the machine and samples of the mis-stitching in for service. It could be the timing needs to be adjusted by a professional.
Feb 20, 2010 | Husqvarna Viking 1
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
194 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
