Question about Acer Aspire 5100 Notebook
Acer 5100 no longer see's the DVD drive... - Acer Aspire 5100 Notebook
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls download this quick fix patch. Expand then merge. This addresses problems such as what you are experiencing in both Vista and XP.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 19, 2008
DVD/RW not recognised by laptop
download everest it's driver software that finds the drivers that are best suited for your computer it has a free 30-day trial (you shouldn't need it for longer) that will for full all your driver needs!
Download Now
Jul 15, 2009 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 8X DVD±RW DL Burner Drive UJ-850 dvd burn only small files, don't burn movies completly. Itried with several programs like nero , image burn,gburn, etc....sometimes works well, the...
Instead of trying to remove the internal drive, which is still useful, do what I did and buy an external DVD drive, just plug it in with a USB cable...then you still have your internal for nornal stuff and you can move the external around anywhere to take care of the heavy duty stuff...good luck..pls rate this solution.
Apr 23, 2009 | Acer Computers & Internet
My DVD drive is no longer recognized
could be a cable has come loose or the reginal settings have been changed
Mar 02, 2009 | Acer Aspire 5100 Notebook
Dvd drive won't work
The drive is probably defective. You can try to reseat the drive. Usually they're held in with one screw on the bottom of the laptop. Once you remove the screw you can just pull the drive out like a drawer and then stick it back in. If it doesn't work then it's likely that it's defective. You can get a replacement on ebay by model number or using the part numbers that are on the drive itself.
Hope this helps!
Feb 19, 2009 | Acer Aspire 5100 Notebook
CD/DVD drive and external harddrives via USB not acessable
I once had a problem like this. It turn out that i just forgot to plug of my external drive. because of the lack of power of the device, it wasnt functioning properly. Try to see if you have two USB plugs, or one Usb plugs with a power cable.  Re check if both of the plugs are indeed connected properly.
Feb 01, 2009 | Acer Aspire 5100 Notebook
Can't get he dvd to work on my acer 5100 after xp installed
You may need to Flash the bios with the bios.
Going from Vista to XP on Acer 5100
The acer website site for the 5100 series located here http://support.acer-euro.com/drivers/notebook/as_5100.html
You can get all the XP drivers for your 5100 series there. Bios also. If the upgraded bios does not fix it then go to control panel, system, device manager, hardware and uninstall the dvd player all together. reboot. If this does not fix it go to the dvd players web site and download a FIRMWARE UPGRADE FOR IT make SURE IT IS THE RIGHT FIRMWARE FOR YOUR DVD PLAYER. Match all numbers and letter that id your drive. Good Luck. Please rate me.
Jan 16, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 21, 2008 | Acer Aspire 5100 Notebook
Acer 5100 cd/dvd drive no longer appears as a device - anywhere
try a disk cleaner it might be dirty inside and they are very sensative
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
