Question about Brother MFC-1970MC Plain Paper Inkjet Fax
I Lost my memory...
I know that U can answer the question in your sleep, however, It has been a few years since I have used my fax machine. It is a Brother mfc-1970mc. My situation is that I don't remember which way to place the paper. Print side down /or print side up when I fax?
Thats All for now.... Thank-U, Diana W.
    Genius:
  • 2,120 Answers
Make a copy of something, then you'll know for sure.
Posted on Dec 18, 2008
Brother 8360p has faxes in memory but will not print them. All the faxes ar going into the memory now. It has paper and toner, check by making a copy. the menu 2 5 4 fax command doesn't do anything,...
I have seen a few Brother faxes do this. I fixed them by turning off the power, holding down the clear/stop button and keep holding it down while you turn the power back on. Keep holding it for a few seconds then release. This will clear what ever is in the memory that is locking up the memory print. Note: you will lose any received faxes in memory by using this procedure.
This may help you restore your fax to a operation condition.
Good Luck and Thank You for using Fixya.
Aug 19, 2010 | Brother FAX-8360P Plain Paper Laser
HP1020 fax answer phone etc
Digital answer phones record the message on a memory chipset in the same way old tape machines did using a magnetic support. Quality can only be improved by the technology itself, problem is with your specific machine.
If you have a broadband filter try replacing it.
Test the machine on a different phone socket and see if it makes any difference.
Check on your answering machine settings, you should find an option to control volume.
Aug 21, 2008 | HP 1040 Plain Paper Inkjet Fax
Fax machine won't answer and pickup. I have to manually pick up the receiver and press start. This just started a few days ago.
You probably have it in the fax/tel or TAD mode. Press the butoon on the top right side of the keyboard marked "mode" until the light above it is on "fax" only. This mode (fax/tel) is for phones/faxes hooked to an answering machine. The "fax" mode puts in into the direct answer mode as a fax machine.
May 22, 2009 | Brother IntelliFAX 4100 Laser Fax
Sleep mode
Have you tried to unplug it, and leave it out for a few minutes, then repower, this clears the volitile memory.
Ed
Apr 17, 2009 | Brother IntelliFax-2820 Laser Fax
Our Brother Intellifax 3800 will go to sleep and ignore attempts to send or receive faxes. It will take a docment into memory and go to sleep and not send it or the phone will ring with an incoming fax and...
i don't have the owners manual handy, but i'm quite sure you can disable the sleep mode by pressing a couples of buttons on control panel. that procedure is in your owners manual on the same page as setting sleep time.
hth,
razors
Mar 16, 2009 | Brother IntelliFAX 4100 Laser Fax
How to use Panasonic KX - FT 67 as an answering machine
hello ,
i am ali , from iran , tehran .
if the fax in memory and paper jamed , what i do clean fax in memory & reset the memory ?
ali_seyedein@yahoo.com
Jan 26, 2009 | Office Equipment & Supplies
"Receiving Sleep" on Brother Fax 4100
you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother IntelliFAX 5750e Laser
Is tel line going into correct socket of fax? (Line not Ext.)
Is Fax set to auto answer or manual?
If you pick up line or press speaker button can you hear other fax sending if so press start and hang up you should receive fax, and you have just proven that machine is in manual receive mode!
I think you will find it  will wake from sleep automaticly if setup correctly.
Oct 11, 2007 | Brother IntelliFAX 5750e Laser Fax
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Sep 04, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother MFC-1970MC Plain Paper Inkjet Fax Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
