Question about Bose Wave Radio
Bose radio hi, we just got our power back on after several days. Our bose radio is totally dead. What do you think has happened to it? Is there something we can do to revive it? Thanks Frenchjeanne
  • bmish4 Dec 21, 2008
    Our electricity was also out for over 1 week, however we were using a generator. The Bose worked the first time we tried it with the generator running but the next day it no longer worked at all. No lights, no sound, nothing.
    I did call Bose and they offered to repair it for $129 and they'd provide a 1 year warranty. Or I can exchange for a newer model for $299.
    President:
  • 2,761 Answers
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Posted on May 21, 2009
When I went to turn the radio on it made a loud squealing noise that will not stop
My radio stopped working and I took it back to the Bose store and they gave me a good credit on a new one. You should give that a try.
Mar 05, 2015 | Bose Wave Radio
My Bose radio will not turn on. I plug it in and the radio lights up and then it goes dead this all happens in about 60 seconds...any suggestions ? I am in Xian China the radio worked fine prior to coming...
If that unit came from the states, the power would be 110V and in China tjhe voltage they use is 220V.
That means, you have to check the fuse in the radio, replace if it is already open.If the fuse is still okay, the power circuit has a burned parts.
My advise is to send it to a electronic tech or the nearby service center.
Hope that helps!
Oct 25, 2011 | Bose Wave Radio
Alarms will not work
Hi. Often following a power outage there is a power surge when the power is restored. If you do not have your Bose protected by plugging it into a surge protector, an internal fuse will blow to protect the rest of the radio. Once that fuse is replaced you will be back up and running. J.
Jul 09, 2010 | Bose Wave Radio II
My bose wave radio wont turn on. It has no power
I have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Jun 06, 2010 | Bose Wave Radio
We can not turn on or charge the Bose. Is there a way to try a new power cord to see if that is the issue?
Which model of the Wave radio is this ? If it is using a 9V battery you might want to check the pcb for some discoloration at the Q4 transistor.
If you have a meter available confirm if it is good or bad. Bose has a
problem with this transistor part# 2SC3792 that is undersized for its
purpose. This transistor provides the 5V for the IC and without the 5V
your radio will look as if it is totally dead with no display and you cannot
turn it on. Typically it is only Q4 that is shorted (0-3 ohms) between the outside (emitter and base) pins. Replacing it with the same part will
bring the radio back to life. Bose recommends a beefier part -
2SD438F-MP-E but it is very hard to obtain. I have used a 2SC2655
without any problem and it is much easier to get.
Jun 01, 2010 | Bose Wave Radio
You didn't mention which model of the Wave Radio you have but since you have a 9V battery it narrows it down to a couple of models. You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
May 19, 2010 | Bose Wave Radio
Help! I have 98 Saturn SL2 that was live one minute dead the next
Sounds exactly like my 1999 SL2 which had "burning and arching" in the fuse box. Car one day be fine the next I'd take it to the store, come back in 10 minutes and wouldn't start, no radio, no power windows, no keyless entry remote, no rear defrost and even locking doors from inside power buttons it sounded odd. This fixed the problem by replacing the fuse box.
Mar 10, 2010 | 1998 Saturn SL
Battery dead after being replaced less than 4 days ago
Run the stereo system through the fuse panel. It will disconnect the power when the key is off.
Aug 12, 2009 | Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35...
Acura radio problem
some redio brands have solution like reprograme your chip but its quit costly so its batter to pay 90 % of new radio than buy new model & use.
THNX
May 16, 2008 | 2002 Acura 3.5RL
Bose Wave Radio Logo
152 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
