Won't play, says open even when the lid is closed.
My memorex MVDP1102 10" portable dvd player has said open since I got it a year ago. I would open and close the lid a couple of times and it would read and play. I had to be careful not to bump it or it would say open. Today I have been unable to play it. The screen says open and then goes blank. It will not read the disc or play. I tried switching the AV switch but no luck. What is the problem and where do I send it to be fixed? I just bought a new battery for $50 and don't want to scrap it.
  • 3 Answers
Well , from your bumping experiences , I would say the latch/hook/switch that tells the player that its lid is closed is loose.Carefully close your lid and see the parts that touch and you will find the latch/hook/switch.Manually play with it (or tape it down!) for a quick fix.For a more permament fix you might have to open it and fashion (or buy) a new switch.
Posted on Dec 18, 2008
When I open the dvd lid, and I put the dvd in and close it, the screen still says its open and it wont do anything until the dvd lid is closed. Even though I close it, the player still thinks its open.
There is a mechanical switch that is operated by the lid as it's closed. Sometimes, a DVD player such as yours can be made to work by pressing down on the lid but this is a sure indication that something is wrong with the switch. It isn't practical to hold the lid down for the entire time you're viewing a movie so repair or replacement is the only solution
Nov 17, 2012 | Mintek MDP-1815 Portable DVD Player
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Memorex mvdp 1085 dvd player, says door open.
our memorex 1085 doesnt play it just buzzes and has a blue screen
Jan 09, 2010 | Memorex Televison & Video
Says open on screen but door is closed and movie wont play
The switch that detects whether the door is open or not could be defective. You can locate the switch by the notch on the disk lid and where it inserts into the base. Try triggering the switch by pocking it with a paper clip while the lid is open. If it says that it is closed and the disc plays then the lid isn't closing securely. If it still says the lid is open after you can hear or feel the switch click then it may need to be replaced.
Jan 07, 2010 | Coby TFDVD1020 Portable DVD Player
I put a dvd in my portable dvd player and close the lid on the dvd player but it keeps sayin its open when its shut!! therefor it wont play any dvds!
LID SWITCH IS BROKEN, CHANGE IT OR THE COVERLID WHICH HAS A SMALL 3MM SIZE OF PLASTIC MATERIAL WHICH PRESS THE SWITCH WHILE CLOSING IS BROKEN TRY TO MODIFY IT...
Oct 13, 2009 | Goodmans GCE5000 Portable DVD Player with...
DVD player turns on; but apperently will NOT play the movie after we put it in... HELP!!!
I had the same issue and could have kicked myself in the ***! Make sure the AV slide switch is in the out position or it will not play at all. As soon as you switch from IN to OUT it will work properly.
May 02, 2009 | Memorex MVDP1088 Portable DVD Player with...
Cover fordisk holder is broken
You can trick the player into thinking the cover is closed and still play DVD's.
Open the lid and notice the small button on the top right side. Pressing the button will simulate the "lid down" so the disks will play.
You can even see the cool red laser when there is no disk.
Aug 10, 2008 | Durabrand DUR-1700 Portable DVD Player
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
Portable dvd player Film's stop and go back to loading screen
Not sure it's a solution, per se, but I discovered that my Matsui was acting as if I was opening and closing it, so I guessed that it was the lid. Once I put a paperweight on the "Press to Open" part of the lid, the DVD played through. I'm looking how to fix the lid but that's a workaround for now. Best of Luck - M
Jan 26, 2008 | Televison & Video
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
