Unable to find service manual for techs to use to fix amplifier
G'day
I bought an XMS503 AV Receiver about 18 months ago, new. Had some problems from the start with the sound cutting out and static would take over. This happened only a couple of times and because of one reason or another, I wasn't able to get the unit back to Strathfield in Hyde Park, Townsville, where I bought it. I haven't used it in about a year and I recently hooked it up and the problem is still there, only it is happening nearly every couple of minutes.
If you press the coaxial button on the remote, or switch it to another unit eg. vcr, then back again and the sound comes back. But after a couple of minutes the sound dissapears and the static comes back!
I put it into a repair shop and they charged me $55 to be able to not fix it. The guy said that he could not find the fault, said the manual volume button was also stuffed and that he needed the service manual or specs for the unit
Strathfield have shut down in Townsville and I have called Head Office and all they say is that their policy is to replace the unit if it is under warranty and if it is not.....too bad! They say there is no-one they know who can obtain the specs the techs need and simply don't want to know about my problem! This unit cost me around $500 and I have hardly used it, and I am not working, so $$$$ are few and far from each other. I was hoping to download the nescessary files but can find no reference for them anywhere. So here I am, writing to you in the hope you are able to give me some advice which will help.
Thanks for your time in reading this
Cheers
Glenn A. Firth
3 Suggested Answers
  • 11 Answers
SOURCE: Receiver shuts down after loud bang
You said Unit is enclosed!! Does that mean it is inside something? Receivers & Amps need to have a clearance above them so air can circulate, otherwise you'll have an overheating problem. You also might have some of your wires crossed which will cause the Amp to shut down. Look at all your connections and make sure they're correct, including speaker wires.
Posted on Sep 23, 2007
No fix to this problem. When my T763 had the same symptoms I left it with the dealer who sent it on to service. It ended up being scrapped. So I'm afraid this is the end of your receiver unless your techies are better than the ones who worked on mine.
Posted on Aug 11, 2009
18 months ago i bought an murphy electric kettle. today the light came on but the kettle did not boil. how long should i ex
Hi Colin, These days some folk would say you were lucky to get 18 months! Cut your losses and buy a cheap and cheerful one!
Jul 11, 2015 | Kitchen Appliances - Others
2003 Scenic 1.9DCI, new clutch, slave flywheel fitted 18 months ago after clutch failure. Last month pedal went flat to the floor and unable to put into gear. Bled system, car ok for a couple of days then...
There are only a few places air can get in the master cylinder and connections the pipe going to concentric slave the connections to slave or slave itself
Feb 05, 2015 | Cars & Trucks
Receiver static
It could be just a lead, check your lead heads and inserts are clean.
Check along your leads and wires for any obvious kinks / tight bends / cuts / nicks / something sitting down on it or any damage to the wires.
It could be there is another electrical device nearby interfering at a electromagnetic level.
It could be just the dials / knobs need taking off and cleaning in behind. the pickups, you may not need to remove them just spray with electronic cleaner b3203b06-4ced-4fda-befd-44f385f97b7e.jpg this stuff is great for lots of different electrical cleaning problems.
Good luck
Feb 10, 2014 | KLH Audio Players & Recorders
When the problem first started i'd punch in the cook time, the only way the microwave would run and heat is if i held up on the outside of the door. Two days later it just quit working all togethe
Call Lowe's to see if the warranty has run out. If still good, take it back. If not, call the manufacturer of the unit and see what the problem is. Sounds like the door support or hinge has weakened and the unit will not operate with the door slightly ajar. Unplug the unit for safety's sake until you find out what is wrong.
Feb 14, 2013 | GE JES1142SJ Microwave Oven
Modle not listed Honda Vision nfme 50 I have had My honda Vision 1986 model for around 18 month. It flew its last mot around 12 month ago. However About 4 month ago returning from work on my scooter...
Its either not getting fuel, poss blocked mainjet, or float needle valve, do you have a constant flow of fuel from the tank, is the bike smoking exsessivly, sounding quieter than it used to do? Maybe the exhaust has become blocked, this was a common factor on this bike, remove exhaust look up exhaust port towards piston, with the piston at the top clean the port with a sharp object scrapeing away all the unburned carbon, start bike up without exhaust and check how it runs,
Aug 29, 2011 | Honda Fusion Motorcycles
How can i upgrade my av 302 to becomes best as konzert av-502
upgrade your 302 to 502 need to replaced the toroid transformer, set of output amplifier, set of electrolytic capacitor.
Purchasing of these parts one-by-one is much expensive rather that you buy a brad new Konzert AV-502. Also upgrading the unit is quite tech and need a lot of experienced in electronics.
Hope that it may help you.
Have a nice day.
JDVillanueva
Jan 31, 2011 | Audio Players & Recorders
No power
may be the coil filter choke is wornout...DC supply stage inside your amplifier...go to the nearest electronic tech to repair that..
May 26, 2010 | AudioBahn A1300HCT Car Audio Amplifier
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
 Grubhead
Grubhead
