Question about Ranger RCI-2995DX Base Scanner
What is the best base mic for 2995
I want a mic that sit on the desk rather than a hand held
  • 8,197 Answers
Go to this site and you can pick the brand of mic. hat you want.
http://www.a1telecom.com/shop/index.php?cPath=27
Good luck and please rate.
Posted on Dec 18, 2008
How do I wire a microphone?
More information please. Re wire existing? Hand mic or desk style? It is often cheaper to buy a new one when you look at the time to do it well. Sometimes you can buy a mic cord and re solder the head to it.
Aug 07, 2015 | Standard Horizon GX1250SA 2-Way Radio
Good carrier but no modulation on my radio shack hand held cb
either the mic or its amp or the modulation circuit has failed
i as its a hand held i suspect the modulation circuir its transformer or audio amp or this subcircuits dc supply
so its a job for a radio engineer with the schematic
and i see the schematic is easily avalible
prob the electret mic small button has become gubbed thru mouth emissions over the years perhaps rusted up
Sep 11, 2014 | Radio Communications
Dont know what size battery to use for a nady ht-3 mic transmitte
To insert the battery, You will need to unscrew the below button part of the hand held mic (anti-clockwise), and after unscrewing, you will see the space to fix in the 9 volt battery..
When you buy the battery,before fixing the battery in, check the polarity before placing the battery in (positive + and negetive -)...After inserting,screw back the cover in and locate where the power switch is..It always has an indicator to know if the power is on...
Note..make sure the Transmitter is on for it to be able to work properly with the hand held microphone....
Good luck..
Sep 07, 2011 | Nady Systems HT-3 Professional Microphone
I recently bought the PC Desk top Miocrophone 600. Plugged it into the back of the computer were mic is at. Nothing Help!!!
Double Click the speaker icon on the right hand bottom ( next to clock ) of the desktop screen.Click options, then click properties. Form the drop down list tick MIC.Now your **** socket is active but by default the MUTE box will be ticked. Untick to enable it. Adjust MIC level for clear sound.
Mar 10, 2011 | Logitech (980240-0403) Microphone
Microphone stand
this confused me too! if you havn't figured it out already there is an adaptor screwed into the mic clip to work with standard mic stand mounts. in order for it to fit on the desk stand that comes with it, you have to to first unscrew the adaptor sitting inside the barrel of the mic clip. then it will be the right size to screw onto the stand.
Apr 01, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
I had a power flicker during the time I was hot syncing my Palm TX. The hot sync did not work, and it would not hot sync at all after that. On advice from Palm's website, I downloaded the latest desk...
If so much has happened to your handheld then the only thing left to be done is a reinstall of the firmware, as that is the only solution to a corrupt firmware because of the power glitch while it was doing something. The glitch has corrupted the firmware and thats how it needs a reinstall. Nothing serious but such things do happen i electronics.
Nov 02, 2009 | Palm TX Handheld
I have many base Radio CM360 have problem in sound no sound but have power i checked in speaker it is good but i need the layout for this model because i have 50 radio have the same model and always have...
Before getting into the radio, I would check the following: If you are using hand mics, or a desk top mic, have you tried unplugging the mic and seeing if your sound returns? It could be a bad mic, mic cord or damaged mic connector.
Another thing to check would be the antenna connections and continuity. It is possible you are simply not receiving.
Dec 06, 2008 | Radio Communications
Ranger RCI-2995DX Base Scanner Logo
453 people viewed this question
Top Ranger Radio Communications Experts
Jon Piercy
perdue40
TekkiDave
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
