Screen appears as if looking through a "scope."
We moved our television from one home to another and now the picture is not filling up the entire screen, as before. It appears as if you are looking through a "scope' all corners are rounded and squeezed.
  • 41 Answers
I would suspect that the back (mirror) has moved ) with out brand and model there is no other help that I can give.
Posted on Dec 18, 2008
How to adjust the screen size
On my remote control for the TV, I look for the # key and press it as many times as necessary to get the correct size picture that is needed to fill the entire screen. Sometimes for some shows, you cannot get the picture to fill the entire screen and then there is nothing you can do to get the picture any larger.
Aug 08, 2015 | Televison & Video
Picture does not fill the screen
Check the main output voltage (B+) from its SMPS regulator side. If this voltage is lesser than normal, picture won't fill the entire screen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mar 31, 2014 | RCA TruFlat 27F520T 27" TV
The entire screen went red and adjustments are not fixing it
The model listed and several near it had issues with the 3 picture tubes--it may be possible to adjust the red screen down---not too hard to do
Oct 16, 2012 | Sony KP-57HW40 57" Rear Projection...
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Expand to full screen. I don't have the manual . I can't seem to get the picture to fill the entire screen.
press menu and move to picture settings and look for format or size if will have either (auto / 16.9 / panaranic / 4.3 displayed change it to full or 16.9
if there is a button on remote with aspect / zoom or format on it press until picture fill screen
Dec 20, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
JVC HD52FA97 PC input won't fill screen.
Check your manual to see what it says about picture aspect for PC input.  My Panasonic looks the same way that you describe and the manual says it is supposed to look that way for PC input.
May 29, 2009 | JVC HD-52FA97 HDTV
Can't read stuff at bottom of screen
it is possible the picture format is set to stretched. look for a button on the remote that can do this. it could also be the signal. try looking at a different channel that has lettering along the top and bottom and determine if the entire picture looks like it needs to be moved up. if after all this you can still determine that the picture is misaligned post the model number and i can help you move it up.
Feb 05, 2009 | Sylvania Televison & Video
Picture screen looks like an hour glass
sounds like your tv is banjaxt!!!!!! get it repaired!!!
Dec 30, 2008 | Philips Magnavox 27MS343S 27" TV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Insufficient vertical height
1 it is due to electrolytic capacitor defective in vrtical output stage. 2 loose contact in vertical. 3 fault due to feedback ckt in v/stage. as per schematic diagram is concern check
Sep 28, 2007 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
