Question about Samsung Digimax L830 Digital Camera
Won't save my pictures
I dropped my camera and the LCD screen broke, but half is still viewable. I was able to take pictures and still view them. Now I try to take a picture, it takes, then I go to view it and it says no image
  • 100 Answers
The lcd screen has to be replaced for this and also need to checked on the main board of the camera that any other minute component on the board is damaged or got broken.
Posted on Dec 18, 2008
I turned my camera on and the lcd screen is white and shows no image. I plugged it into my computer and the pictures are still intact, and the camera is able to take pictures, but I can not view them on...
Try restarting your camera a few times and see if that solves the problem. I would suggest saving all of your pictures and reset the camera if possible. Sony's quality of their cybershots are quite sub-par and common things like an LCD shorting out is quite frequent, so you may have to call the manufacturer to replace/repair your camera.
Mar 06, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D200 - No preview lcd display does have playback display of shots taken. Does have data modes viewable. battery is good
The D200 works as SLRs have worked for half a century. You compose the picture through the viewfinder. Only more recent dSLRs have the live view capability, allowing you to hold the camera out at the end of a wobbly arm instead of tucked in against your body. In the case of Nikon, this capability came out with the D3 and the D300.
Jul 05, 2010 | Cameras
White out LCD screen
Try a manual reset. Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Oct 05, 2009 | Kodak EasyShare C713 Digital Camera
LCD screen for Polaroid i634
hi ,you could try to contact here to get replacement for lcd screen of TD025THEEA http://szaideal.diytrade.com/
Jan 27, 2009 | Polaroid i634 Digital Camera
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Fuji s 20 pro
CCD module failed, contact fuji, they got product recall for some camera models with faulty CCD
Mar 06, 2008 | Fuji FinePix S20 Pro Digital Camera
Camera Screen
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Jan 25, 2008 | Kodak EasyShare V603 Digital Camera
Green pictures
Unfortuantely not. It looks like the the LCD has been damaged. They are, as you now know, expensive to repair! Maybe your household insurance might be able to cover it?
Jan 16, 2008 | Fuji FinePix F20 Digital Camera
Problem with my D50 reading my card
Try resetting all folders in the camera to default setting or erasing any existing folders in the camera, then insert your card.
Oct 27, 2007 | Nikon D50 Digital Camera
Samsung Digimax L830 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
