Question about Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television
Hook up portable dvd to tv
How do i hook up my digital labs portable dvd to my tv?
i have a red and yellow wire.
I also have a three wire - with one plug on one side and three on the other?
    Novelist:
  • 152 Answers
Hello, you can connect to inputs 1 or 2
yellow is video, red is sound,
use the inputs 1 or 2 on the back of the tv
it is recomended to use a rca type 3 way for both left and right sound channels
white left sound
red right sound
yellow video
hope this helps
good luck and happy holidays
Posted on Dec 18, 2008
    Sergeant:
    Champion:
  • 250 Answers
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
How does one hook up a DVD/CD to a digatal TV
well since you have a digital tv (you have all sorts of jacks in the back or side panel)...your dvd has 3 (rca) cable wires (yellow/red/white)..we need to plug these three wires into the back of tv where its video in (depending on your set it might say dvd/digital in or whatever)...once you have did this in order to see the dvd using the remote switch the source (between tv/av1/av2 or cable)..remember your tv stays on ch 3....to get back to your regular tv again using the remote for the tv switch the source to tv/cable''
feel free to rate the help
Jul 03, 2010 | Sony DVP-NS710H/B DVD Player
Okay i have a digital labs 19" LCD HDTV/DVD and it works fine until you hook it up to an antenna cable, then it wont give channels when i auto scan. what should i do? buy a new cable or is it the tv
I have the same problem. Seemed to work fine with digital cable, but after switching to Dish Network, no luck. If I plug the AV cables (red/white/yellow) directly into the dish receiver, it works fine. The problem happens when I use it as a second TV connected via the RF cable wire. My only guess is that the dish receiver transmits the signal to the second TV via NTSC ... and the Digital Labs TV only supports ATSC and QAM. Hoping someone can confirm?
Jan 05, 2010 | eVision Televison & Video
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
DVD Player connection to the tv... Theres three different colours on each side (red, white, and yellow) I already got it hooked up to the tv but the problem is that to hook the other end into the DVD...
Red is usually the left channel audio, white the right channel audio, and yellow the video. Look for something to the effect of "audio out" and "video out" on your DVD player.
Jul 07, 2009 | Norcent Technologies E-DVKIT003 10.2 in....
Hook up portable dvd player to tv
If you have component out jacks in the back (yellow, white, red plugs) you should be able to buy plugging them into your TV's Component IN jacks.
May 21, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
How do i hook up the portable dvd to my tv? I have two types of sets of wires. One is a separate yellow and red wire. the other are three wires connected with only one plug on the other side.
the two different wires you have are: yellow and red wire set are regular RCA's, and the other set sounds like component wire set. I myself would use the component wire set. let me know if that works for you.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
I have the cord to hook up the portable to a tv.
Yellow-White and Red will hook to AV Input in TV and you can find same colors female pins at back of TV.
Nov 28, 2008 | Sony DVP-FX810 Portable DVD Player
How do i connect to my tv?
the yellow line is for the video the red and white is for the audio, and you can connect your DVD to your TV.
Oct 02, 2007 | Coby DVD-207 Portable DVD Player
Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television Logo
344 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
