Question about Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television
How do i hook up the portable dvd to my tv? I have two types of sets of wires. One is a separate yellow and red wire. the other are three wires connected with only one plug on the other side.
    Sergeant:
    Champion:
  • 247 Answers
The two different wires you have are: yellow and red wire set are regular RCA's, and the other set sounds like component wire set. I myself would use the component wire set. let me know if that works for you.
Posted on Dec 18, 2008
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
HOW DO I HOOK UP RCA 9IN COLOR TV MODEL 9V345T TO A DVD OR VCR
With TVs, the cable connections (red, white and yellow) are usually on the back of the TV, but if they are on the front, when facing the TV, the spot to put in the cables are on the left side of the TV. with most all DVD and VCR players, the wire hook-ups are on the back, and are color-coded, idiot-proof, no offense, that was not directed to you.
Oct 01, 2010 | RCA 9V345T 9 in. Portable Television
How many wires go from DVD to TV and what colors are they?
Ok. If you have a tv that has a five hole input (green, blue, red, white, red) this is the preferred hook up. That cable is called a component cable. The green blue and red part is for video and the white is audio left and the red is audio right.
If your tv does not have the five hole input it should have a three hole input. Those colors are yellow, white, and red. This is called a composite cable.
You just match up the colors that's all. Your tv should have an input or tv video button on the remote control that would allow you to switch inputs or you may be able to get to video 1 and video 2 and etc by using the channel up and down button and going lower than channel 2.
May 06, 2010 | Sony DVP-NS575P DVD Player
How do you wire up a alpine tve-t850? what is the red black and yellow wires
the red, white and yellow wire, helps to connect DVD or VCR players into the television.
Once the DVD or VCR is connected, then you will press the AV of the TV to view the DVD or VCR.
The Yellow wire is video (Visual) while white and red are for sound ( Audio L & R).
Take care.
Jan 05, 2010 | Televison & Video
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
RCA TV need to hook up to DVD
try going to there website and download the manual under the download section and type in the model and serial numberand see if its there usually on most output from dvd to t v input the three wires yellow white and red and thats all
Aug 10, 2009 | RCA Televison & Video
DVD Player connection to the tv... Theres three different colours on each side (red, white, and yellow) I already got it hooked up to the tv but the problem is that to hook the other end into the DVD...
Red is usually the left channel audio, white the right channel audio, and yellow the video. Look for something to the effect of "audio out" and "video out" on your DVD player.
Jul 07, 2009 | Norcent Technologies E-DVKIT003 10.2 in....
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television Logo
60 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
