Question about MSI K8N Neo Platinum Motherboard
Problem with IDE & SATA Hard Disk
HI, i have winx xp on a 60gb IDE hard drive, yesterday i bought a 160gb Sata HD but my system don't show it as secondary HD. i just want to know how do i have to configure the bios or what to do to use both HD and the SATA as secondary. kindly regards for the help
  • Luis Dec 18, 2008
    thnx, maybe its the jumper, the SATA HD dind't have one in fact i though SATA HD's doesn't use jumpers
    President:
  • 2,110 Answers
Have u tried changing ur jumper setting..which u can find near the power cable to the hard disk...and also U have to enable SATA hard disk in BIOS..
Posted on Dec 18, 2008
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
Mar 25, 2012 | Computers & Internet
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
MSI K8N Neo Platinum Motherboard Logo
141 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
