Question about General Electric WPGT9150H Top Load Washer
Water pouring out of u-shaped slot at the bottom of tub.
The slot shape is like horseshoe , is there a plug missing ?
PE PROBLEM OCCURING IN FRONT DOOR LG WASHING MACHINE
Posted on Dec 18, 2008
Dishwasher Does not Fill Past First Rinse
There is an anti flood valve on the bottom of the unit. IT could be sticking or have a bad connection. IT should look like a dome shaped housing on the bottom of the tub. If that is not the problem then you are looking at further troubleshooting to see if it is the contoller.
Jan 19, 2014 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water is leaking inside refrigerator from back of refrigerator . it is dripping form the(J shaped plastic piece in middle) that holds the light bulb. I have cleaned the refrigerator, ,pulled out the tray...
There should be a drain there somewhere by the J shaped plastic piece you need to pour some hot water down it and follow up with a curtain wire down there too, to clear it out :)
Jun 07, 2011 | Whirlpool Refrigerators
The hot water is not working at our tub. we had the water turned off for a couple months and I believe sediment is in the line. The hot water works everywhere except at this one tub. i need instructions on...
Your problem is most likely a bad cartridge.#1 turn off water in house #2 remove handle #3 you will see a horseshoe shaped clip that holds in cartridge remove clip and try to pull cartridge straight out you may need to purchase a moen cartridge removal tool for easier removal and install new cartridge and replace horseclip
Nov 14, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Sort of horseshoe shape exclamation mark in middle
its the tyre pressure monitoring system...check for a deflated tyre
Nov 09, 2009 | 2004 Mini Cooper
Put water into radiator pours out of overflow
Make sure your drain plug at the bottom of the radiator is tight and un damaged. The 2 aluminum lines are for your automatic transmission and should not be messed with.
Oct 12, 2009 | 1991 Pontiac Grand Am
Double image w/horseshoe shape top and bottom
sounds like the convergence amplifiers need to be replaced
Dec 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
General Electric WPGT9150H Top Load Washer Logo
51 people viewed this question
Top General Washing Machines Experts
Sal De
Kevin
Kevin
geapptech
Are you a General Washing Machine Expert? Answer questions, earn points and help others
