Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Computer doesn't recognize my Lacie HD
I've had my 750GB d2 Quadra for about 4-5 months now that I use with my macbook. It's worked fine with no problems until about five days ago when my computer just stopped recognizing the HD. I would say that two or three days before the power adapter started making more noise, but it still worked fine.
Now when I plug in the HD it sounds like it has trouble getting started as if the hardware inside just isn't moving the way it should, but when I stand it upright it starts to spin after about a minute. My computer, however, still does not recognize the HD.
I've gone into DiskUtilities and the computer sees that the HD is connected, but I can't repair it. I have the option to erase, but obviously don't want to do that because I'll certainly loose 50GB of files.
Any tips here?
I've gone into
  • 1 more comment
  • brandonfi825 Dec 18, 2008
    I should also mention that, when I move the HD it sounds as though something has come loose inside of the casing.
  • Anonymous Dec 28, 2008
    i think that i have the same problem with the same drive
    in my vista OP it used to work just fine and the next day it turned on and every thing is fine until i connected it to my laptop but it isn't reconized
    formatting IS NOT AN OPTION cuz i'll lose about 250GB woth of files
  • hamburgerman Feb 15, 2009
    i have a LaCie 500 USB 2.0 external drive. For months I left it on with no problems. One day I decided to turn it off, and the next day when I turned everything back on, the computer would not recognize the drive. I have no idea what happened.
  • 846 Answers
From your description it sounds like you power adapter did indeed fail at first, but if the HDD spins now the adapter seems to be working fine at the moment. If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Posted on Jul 04, 2010
Drive stopped responding -- problem with power supply or drive?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 05, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My 500gb lacie d2 hd quadra is no more recognized by my macbook pro sys 10.7.3 (lion)???...
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
May 10, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
LaCie d2 Quadra is inert: service/repair or buy new one?
Check with LaCie's support site at http://www.lacie.com/us/support/ and it's a good idea that you write down the serial number of your external disk.
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
Lacie d2 Quadra 750gb HD, making werring,clicking noise.
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
May 13, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Installed on MAC, then Plugged it to PC, now MAC won't recognize Drive
look into Disk Warrior...its a hundred bucks, but it is a miracle worker of sorts and might fix everything for you.
the frustrating thing about DW besides its $100, is it takes less than a minute to fix problems I would fret over for weeks
Dec 29, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
694 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
