Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 Wont Boot To Start....
My Laptop wont boot, it restarts again & After trying everty option given to me from the few "Menu" Screens I've found my way into and have got no where just false hope... Now however I'm on this "EDIT BOOT OPTIONS" screen... It's seems that if I knew what to type in I could Undo whatever the issue is. Can someone please help me figure out what I do from here?
It reads: Edit Windows boot options: Microsoft Windows Vista
Path: \Windows\system32\winload.exe
Partition: 2
Hard Disk: af0c9839
[ /MAXMEM=939524096 /NOEXECUTE=OPTOUT /NUMPROC=2 /SAFEBOOT:MINIMAL /DETEC
THAL /PCILOCK /DEBUG FOLLOWED BY A THICK WHIT CURSOR AND IT ALLOWS ME TO TYPE IN ANYTHING... So is there something I should write? Rewrite? Please help me figure this out withoue having to take my laptop in for repair or with out recovery disks. I have none, only if I absolutely must I'll take it in or by the disks...
So can anyone please, pretty, pretty please help my sorry lil broke self?
  • Anonymous Dec 18, 2008
    same here
  • 22 Answers
Try booting in safe mode. you may want to first try loading the last known good configuration.
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key. Let computer boot to safe mode and then shutdown. If problem continues then Start in safe mode again.
After you boot to safe mode then go to Control Panel, System, Advanced System Settings, Advanced tab should be at the forefront. Go towards the bottom of the popup (Startup and Recovery) and select settings. Then in the settings popoup uncheck Automatically Restart. OK and apply everyithing then restart computer. Let me know what happens.
Posted on Dec 19, 2008
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
May 25, 2013 | Acer Aspire 5742Z-4601 : 2GHz Pentium...
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
My acer 5100 laptop will not boot up. I get
you could try going to the boot menu, and choosing 'last known good', but that is probably not going to work.
you should be able to run a repair off the CD....
the file is a kernel, a neccessary file used by Windows. It may have gotten corrupted or deleted.. possibly by a virus or bad hard drive sector.
get a disc, and run repair, if that doesn't fix it, you may need to re-install a fresh copy of windows, which will over-write all your data. you may be able to boot to that upgrade CD and that may have a repair option...
good luck.
Sep 11, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 wont boot, and I'mnow on this "EDIT BOOT OPTIONS" screen... It's seems that if I knew what to type in I could Undo whatever the issue is. Can someone please help me figure out what I do...
edit boot options is the order in which your computer will reboot... select hard drive... if it does not successfully boot up... reboot and tap the F8 key.... boot to last known good configuration... if that doesn't work... reboot... F8 the safe mode... if it will boot to safe mode reboot normally... should be fine
Dec 18, 2008 | Acer Aspire 5100 Notebook
ACER ASPIRE 5100 WONT BOOT
Your harddisk MBR sector might be damaged, google fix mbr and resetup your harddisk mbr. After that it most likely will boot.
Dec 12, 2008 | Acer Aspire 5100 Notebook
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
My Acer Aspire 5100 wont start up correctly
please email me for more info on problem, meanness628@aim.com
Jun 25, 2008 | Acer Aspire 5100-5033 Notebook
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
ACER PC 5100 Problem
It sounds like you have some internal hardware problems. It is best if you have an exprat inspect you laptop interior power connections and inspect your BIOs options for boot sequence.
Feb 18, 2008 | Acer Aspire 5100 Notebook
Windows will not boot
Just turn-off network boot in your bios
Nov 15, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
