Question about Brother MFC-9420CN All-In-One Laser Printer
Is there a waste ink absorber on a Brother MFC 420CN?
If there is how do you replace it. My printer keeps giving me an "unable to clean" error message. There is nothing jammed and I tried unplugging and plugging back in. I read that it might be the ink absorber but I cannot find any info on it. Thanks
  • Anonymous Feb 08, 2009
    waste ink absorber box
MFC420CN waste ink absorber how do you replace it or clean it ?
Posted on Jan 19, 2009
Brother MFC-420CN still unable to clean even after purge reset
You will need to take the scanner unit off and the cover tray. Many screws and clips to find and release. Once you have removed all that, you will find a container located just behind the cartridge bay that looks like it is full of black cotton pads - it is and that's the thing to very carefully remove. Use a bucket or laundry sink to remove the pads and note the order in which the are layered. Wash them out with water until the are relatively clean. Dry them and reassemble in order. Replace everything in reverse order and turn your machine on. You may need to run the maintenance code set again.
Nov 01, 2017 | Brother MFC 420CN All-In-One InkJet...
Unable to clean 4f
you need to reset the purge counter (waste ink absorber full)
Feb 24, 2011 | Brother MFC 420CN All-In-One InkJet...
Printer is giving a uable to clean error
That error happens when the ink absorber is full and you need a shop to replace the absorber box and reset the ink counts.
Jan 04, 2010 | Brother MFC 420CN All-In-One InkJet...
Printer que " unable to clean see troubleshooting in manual"
Unable to clean usually means the waste ink tank is full, the only repair is to replace the tank, aprox. $10.00 and reset the counter to clear the error. If you clear the error without a new tank you risk ink overflow inside the machine and on your table...
Aug 19, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to clean error message can selext "all or Color after hitting ink button
This is very common on Brother MFCs - they self clean excessively and when they've done a set number of self-cleans, they refuse to print and give the error message you quote.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Aug 16, 2009 | Brother MFC 420CN All-In-One InkJet...
MFC-420CN error "Unable to Clean"
Unable to clean comes up as well when the ink absorber is full. It won't let you print or
clean until a fresh absorber is installed, as it could leak all over inside and out. A shop has to do the repair.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Brother 420cn printer
You cant clean the ink absorber box. Go see www.brother.com and choose a service partner next your home. Buy a box as a spare part.
see pics how to open printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google translation; language is german)
Search fixya for error 46 or unable to clean on how to reset the eeprom.
Apr 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Error message
You need a new waist ink absorber which can be bought as a spare part from a service partner near your home.
When the absorber is replaced you have to do a eeprom reset.
search error 46 which is quite often explained in this forum.
Mar 27, 2008 | Brother MFC 420CN All-In-One InkJet...
Cannot print
The ink absorber box is fed up with waist ink. You have to buy a new absorber box from a service partner which can be found on the brother homepage of your country. Ther is no way to clean the box!
When you have the absorber box plz post here again.
Ill give you some details on how to change the box and do the eeprom reset.
Dec 15, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-9420CN All-In-One Laser Printer Logo
777 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
