Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 wont boot, and I'mnow on this "EDIT BOOT OPTIONS" screen... It's seems that if I knew what to type in I could Undo whatever the issue is. Can someone please help me figure out what I do from here?
  • princessa351
    princessa351 Dec 18, 2008
    Thanks for the advice, really, but I've done all that and gotten nowhere still. If someone knows what I should change on the screen I'm stuk on I would be so greatful.... EDIT BOOT OPTIONS , on black screen...
    Brigadier General:
  • 5,158 Answers
Edit boot options is the order in which your computer will reboot... select hard drive... if it does not successfully boot up... reboot and tap the F8 key.... boot to last known good configuration... if that doesn't work... reboot... F8 the safe mode... if it will boot to safe mode reboot normally... should be fine
Posted on Dec 18, 2008
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
Acer aspire 5100-3583 boots, screen is on, but
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 07, 2017 | Acer Aspire 5100-5033 Notebook
Acer 5920 boot up problem.
can u describe which operating system u r using and what error u get and what u choose in boot options?
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
How to restore my acer aspire 5001 to factory settings i tried the normal restore but it dont work can you help pls ,,cheers neil
Hi I contacted Acer about this myself and this is what they wrote back.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jul 09, 2009 | Acer Aspire 5100 Notebook
Windows vista ultimate will not boot up
Press enter and submit the changes :) computer should repair itself from a back up file and start as normal.
Regards
Jun 08, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 5100 won't system restore
If you created your system restore CDs when you purchased the system, insert your first CD into the CD drive and boot your computer. This will restore your computer to factory settings. ALL DATA WILL BE LOST.
Apr 02, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Wont Boot To Start....
Try booting in safe mode. you may want to first try loading the last known good configuration.
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key. Let computer boot to safe mode and then shutdown. If problem continues then Start in safe mode again.
After you boot to safe mode then go to Control Panel, System, Advanced System Settings, Advanced tab should be at the forefront. Go towards the bottom of the popup (Startup and Recovery) and select settings. Then in the settings popoup uncheck Automatically Restart. OK and apply everyithing then restart computer. Let me know what happens.
Dec 18, 2008 | Acer Aspire 5100 Notebook
ACER ASPIRE 5100 WONT BOOT
Your harddisk MBR sector might be damaged, google fix mbr and resetup your harddisk mbr. After that it most likely will boot.
Dec 12, 2008 | Acer Aspire 5100 Notebook
Acer recovery disc wont work
u cant use recovery disk u need orginal vista dvd or xp cd boot into that then formatt ect
Jan 28, 2008 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 Notebook Logo
212 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
