Question about Dell Latitude D600 Notebook
Due to a virus problem, I have had to install windows (xp) on my laptop but in device manager under other devices the following item has yellow question marks:- network controller what should i do to get the internet?
    Brigadier General:
  • 5,158 Answers
Go here... select the model etc and the network driver should be one of the drivers available... download it and install and that should fix it up.
http://support.dell.com/support/downloads/index.aspx
Robert
Posted on Dec 18, 2008
I am unable to scan a document to save and them pull it up to a word processing program in order to edit it. I am using hp, 1200 series, version 2.10. Is there a version that would allow me to do...
If you want to edit a scan in a word processor, you'll need another program called OCR: optical character recognition. This program reads the scanned bitmap, tiff or jpeg, and converts it to text.
Whether or not an OCR program was bundled with your scanner or not is another story, and typically expects that you will use your existing scanner software to save an image to disk somewhere, in a format that OCR will understand.
You may wish to clarify whether the problem is the scanner (unable to scan), the driver that came with it (unable to save), or the OCR software (unable to export to word for editing).
Sep 15, 2008 | HP Office Equipment & Supplies
Trying to install ncomputing u170 on Win 7 Ultimate 32 bit desktop. Immediately following the install of the vendors software for the Win 7 os, windows tells me that the software has been disabled due to...
You may need to remove your anti-virus program first before you install the u170 driver. after installing then you can put your anti-virus back in. If that didn't work, right click the installation file then click on properties then click on the compatibility tab. Put a check mark on "Run this program in compatibility mode" then choose windows XP (service pack 3) then click on OK then try to install the driver. Remember, you need to do this without an anti-virus program in your computer.
Jan 01, 2011 | Computers & Internet
Hello My problem is that I have A Toshiba Satellite A100 model laptop. I have formated it and install windows XP Professional in it. It install successfully and it also find network adapter 1394...
The devices that have a yellow ? against indicated that device drivers was not installed.
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
May 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
No wifi after re-load of xp system software
Did you reinstall the drivers for the device? Check the Device Manager for your system and see if Windows sees the wireless device. If you have a red X, the device is disabled; if you have either an unknown device or the wireless device with a yellow dot with a black exclamation point, then either the driver is not installed, or the driver is improperly installed.
Mar 24, 2009 | HP Pavilion zd8000 Notebook
Modem device on high definition Audio Bus for acer aspire 3680
These are the same thing , they will both disappear when you install the audio driver
http://support.acer-euro.com/drivers/notebook/as_3680.html
Click under Windows XP Drivers And Utilities And click Audio Driver
Always check the manufacturers site for your drivers!
Jan 24, 2009 | Acer Aspire 3680 Laptop
CF-73 Wireless Problem
You may need to install the driver for your wireless adapter manually. Go to Device Manager > Look for "Other Devices". Under "Other Devices" look for an item that could be your wireless adapter (trial and error method) , right click it and select update driver. Your wireless adapter can sometimes be "Network Controller" under Other Devices. If your first item under "Other Devices" does not recognize the driver that you supplied, proceed with the next item. Make sure you have the correct driver.
Good luck and have a nice day!
Sep 29, 2008 | Panasonic Toughbook CF-73 Notebook
Blank page printing-Lexmark x1240
try turning off the printer then reboot the PC, then turn on the printer if this doesn't work try the software may not be installed properly. Try the following:
1 Right-click the My computer icon.
For Windows XP, click Start to access the My computer icon.
2 Click Properties.
3 For Windows 98 or Windows Me, click the Device Manager tab.
For Windows 2000 or Windows XP, select the Hardware tab, and then click
the Device Manager button.
4 Look for the Other Devices category. If there are any Lexmark devices
shown here, highlight them and, then press the Delete key.
Note: The Other Devices category appears only when unknown devices
are present. Do not delete any Lexmark items unless they are
present under the Other Devices category.
5 Insert the CD, and install the software again. Do not restart the computer.
Sep 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
Won't scan or copy
Solution
These errors are usually caused by a failed scan, a bad installation, communication problems or software conflicts. Follow the steps below until the problem is corrected.
Step one: Restart the computer
Close all programs and restart the computer. A required task might have stopped running or the system resources might have decreased due to tasks left running. Restarting the computer will refresh all Windows tasks as well as increase the available system resources.
Step two: Check for the correct entries in the Device Manager
Verify that the unit was installed on a DOT4 virtual port in the Device Manager.
  1. Right-click My Computer , and then click Properties .
  2. Click the Device Manager tab. (In Windows 2000 and XP, click the Hardware tab , and then click Device Manager .)
Check the list of installed devices for references to DOT4. If there are no DOT4 references, the software has not installed correctly.
If any of these entries are missing, the software did not install properly. Review the information in the HP document Troubleshooting Installation Issues for USB-Connected HP All-in-One Products in Microsoft(R) Windows (bpu01858) for installation assistance.
Step three: Check for communication problems between the all-in-one and the computer
Communication might have failed between the all-in-one and the computer. Review the information in the HP document USB Connected HP All-in-One's Software Reports a Disconnected or an Error Status (bpu01859) to check for communications problems between the HP all-in-one and the computer.
Step four: Check the computer to see if it is infected with a computer virus
If the all-in-one prints but will not scan correctly and does not show any symptoms of communications problems, the computer might be infected with a virus. Some viruses try to disable virus scanning software and in doing so disable scanning from the all-in-one. The following are symptoms a virus problem:
  • The scanning software works after installing the all-in-one software until the first time the computer is restarted.
  • In the Device Manager, opening the Properties of the Imaging Device entry will reveal a status of "code 19" or "code 28".
  • A Scanner Cannot be initialized error occurs. While this error may other reasons, a virus will cause this error.
When the all-in-one is turned on and connected, follow the steps below to see if this is the problem:
  1. Right-click My Computer (click Start first in Windows XP) and then click Properties .
  2. Open the Device Manager:
    • Windows 98 and Me: Select the Device Manager tab.
    • Windows 2000 and XP: Select the Hardware tab, and then click Device Manager .
  3. Locate the Imaging Device entry and click the plus (+) beside it. It may have an exclamation mark beside it.
  4. Right-click the all-in-one entry under Imaging Devices, and then click Properties .
  5. A Properties screen will open. Look at the Device status section.
Hope it may helps;.
Regards, VOTIT
Sep 20, 2008 | HP Photosmart C4180 All-In-One InkJet...
Dell Latitude D600 Notebook Logo
97 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
