Back to:
Tags:
Nview Z215 10.4
How do I adjust the frequency for an external...
By Chandler - usenet poster
How do I adjust the frequency for an external monitor (projector)?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2005
Helpful (85)
maartenw
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Some people have had problems hooking up Mac laptops to projectors at other institutions (where, often, the support people know nothing about Macs). It is sometimes suggested to try reducing the frequency of the monitor output.
If you just use the control strip widget, only the "Recommended" settings for an external monitor will be shown. You need to open the Monitors control panel while the external monitor or projector is attached. Then, above the list of pixel resolution and frequency settings, choose "All". You will then be able to select the "suboptimal" settings that might get the projector to work (e.g., 1024 by 768, 60 Hz instead of 75 Hz).
Also see the caveat above about using the LitePro -- some projector will accept higher pixel resolutions than their native mode, which then tend to look crappy.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How do I adjust the frequency for an external monitor (projector)?:
I don't want to Accept this solution
Solution #2
posted on Dec 03, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
(FN+F8)
Thank You!
Can you Help with these Multimedia Projectors problems?
Nview Z215 10.4" LCD Panel with Video(16.7...
My colour balance is all wrong, as if there is no red. I...
John Bowen, Just bought unit, powers up, lamp comes on and...
Hi, I have a DLP projector, model HP VP6311. When I switch...
If anyone can solve this, you are a genius! I am using a...
When I turn on ACER PH110 light get light up and then it...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
