Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell E152 Flat Panel screen is REALLY dim.
I have a Dell E152 flat panel monitor that doesn't work correctly. It turns on and the green light comes on, but the display can barely be seen. I believe the backlight is no longer working. You have to look extremely hard to see the display...basically....the display is extremely dim. Any help is greatly appreciated. Also, could someone explain how to properly disassemble these monitors? There are screws in the back of them that i've never seen before....they look like holes for screws. Thanks.
  • Dell Master
  • 1,626 Answers
I haven't seen this particular monitor. It may have deeply recessed black screws, or possibly even Torx screws. Try a #2 Phillips and see if it engages firmly. If not, try a T-10. Once you get inside, you will need to remove the power supply and main board to get at the LCD panel. Locate the inverter circuit - it will have two Teflon insulated wires going to (usually) the bottom corners of the panel. It may be part of the power supply board. Every LCD display I've seen so far uses pink colored insulation on those wires. It is possible that the inverter has failed, but most of the time, it's the fluorescent tubes inside the back of the panel.
Getting at the tubes without breaking something is not a trivial task. You will most likely need a #00 Phillips screw to remove the shield metal. Observe anti-static precautions from the moment you open the monitor. Be patient, and keep track of every part or connection you remove. Do not remove the LCD driver circuitry (generally at the top) from the panel. The tube(s) are usually at bottom, enclosed in a sheet metal reflector held in place by the bottom section of the thin metal frame around the panel, just inside a flexible white plastic sheet that covers most of the back of the panel.
You can get new backlight fluorescent tubes from www.lcdparts.com. This website has links to some very helpful pages on repairing LCDs. Note: replacing the tubes involves some rather delicate work. If you are nervous, twitchy or clumsy with fine work, you'd be better off to hire out the job. Be very careful not to rip the rubber insulators on the ends of the tubes when you slide them down the insulated wires to expose the connections to the tubes. You have to attach the wires at just the right spot or you won't be able to fit the insulators back on and get the new tubes to go into the LCD frame - and you can't apply heat to the wires for more than 4 seconds at a time. I've done a number of them successfully, but have occasionally had to try several times to make the connection sufficiently small and short.
Posted on Dec 18, 2008
Service manual dell e173fpf
Try here:
http://elektrotanya.com/?q=showresult&megnev=dell&megnev2=e173&kategoria=&kat2=all
Most E152/153.172/173 have same problem, poor solder joints, blown fuse, shorted transistors.
http://s807.photobucket.com/home/budm/allalbums
Replacement bd: www.lcdrepair.us
Hope it helps. Please post back.
May 03, 2010 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell e152FPB LCD monitor backlight power problem
Check the four transistors (c5707/5706) in the inverter section for shorts, board looks like this? http://www.lcdrepair.us/e152-e153fpb-inverter-power.html
Feb 20, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Monitor turns off and is dim
replace pwr inverter board...
replace the video/keyboard as well...
Feb 08, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Screen not working
there is a problem with the degausing coil of the monitor. just open the case and try to clean the degausing coil. thx jsut vote for me so that i can help u better.
Aug 29, 2007 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Dell ultrasharp 15 inch flat panel lcd
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell flat panel monitor
It's a problem in the power supply section inside the monitor. It needs component-level electronic troubleshoting.
Jan 16, 2007 | Kogi l4bx-na ko 14.1" Flat Panel LCD...
Dell E172FP 17" LCD Flat Panel Monitor Logo
325 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
