Sony Trinitron XBR - won't turn on
Hi - read your post.
Same problem here - try to turn it on - makes the typical TV sound - then blinks sometimes 4x - sometimes 6x -- then goes into standby mode.
We live in the San Fernando Valley area. Would like to see if we can get this fixed for a reasonable cost (instead of the $1500 to $2000 we were going to spend on a new TV)
Can you help?
Thanks
    Top Expert:
  • Televison & ... Master
  • 27,169 Answers
Four blinks means vertical scan issues and six blinks means line stage issues. I would repair the power supply first as if the HT fails to start, the software won't know whether line or field has failed and may bring up both codes at random.
Probably just dry capacitors.
Posted on Jul 28, 2017
  • 4234 Answers
SOURCE: stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Posted on Oct 02, 2008
  • 61 Answers
SOURCE: My Sony Trinitron won't turn on...has 4 blinks in Standby.
There are 3 reasons for 4 blinls
1.unit went to stand by mode because of h-pulse
2.Vertical defflection pulse stopped
3. power line is shhorted or power supply is stoped.
Solution:
1. check 13vdc on A board of powersupply stage
2. Check IC561 on A-board.
Good Luck
Dals123
Posted on Oct 15, 2008
SOURCE: sony xbr standby light problem power wont turn on?
the problem either in short horizontal output x-sistor or in power supply unit.
Posted on Oct 20, 2008
SOURCE: Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Posted on Feb 20, 2009
  • 116 Answers
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Posted on Apr 15, 2009
My sony trinitron xbr won't come on when the remote iis pressed it only clicks.. no picture or sound
Your problem could be any one of the boards in the set. When a flat screen attemps to turn on, but finds an internal problem, it defaults by clicking off to keep the remaining circuits and boards from buring up. You'le have to take the tv to a shop. Sorry that I can't be of more assistance.
"Original Radio Man"
Ed
Feb 13, 2013 | Televison & Video
My sony trinitron xbr tv turns on stays on a few seconds then powers off by its self and it gives 5 red blinks from stand-by
This is according to the sony service manual
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Sounds like a failure in the C Board or AKB Circuit.
Best to take it in to a service center.
May 30, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Trinitron XBR, Stand By Mode?
Generically, the 6 or 7 blinks usually indicate a problem with the horizontal circuit. In order to provide accurate diagnosis and suggested solutions, the exact model number is needed. Please update this with tha number and I will post more details.
Thanks,
Dan
Mar 18, 2009 | Televison & Video
Sony Trinitron KV36XBR300
Best thing to do is get 3-4 people to haul it to the curb. That is a high voltage failure which can be related to a bad tube or flyback. That TV is too old to get parts for and not worth spending a single dime on.
Feb 02, 2018 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Sep 16, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
check your lamp cover and make sure it is not loose. of so take a philips screwdriver an tighten the cover screw.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
