Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Honeywell th6300b deluxe
Install thermostat and was working good during the summer, i switch to the heater and its not heating to temp. .To temp. stays at 68 degrees, i see te furnace ignite but no heat coming from vents, it runs about 3 minutes then shut off. Sometimes it comes on and pumps heat once a day then shuts off, thats it. The program is set right but no heat.
  • Allen Neal
    Allen Neal May 11, 2010
    tell me the furnace type and type of fuel
    Top Expert:
  • Honeywell Master
  • 7,905 Answers
Make sure fan on auto
Posted on Oct 18, 2017
  • 3 Answers
SOURCE: Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Posted on Feb 12, 2009
  • 6 Answers
SOURCE: Honeywell thermostat won't regulate temp properly
Is there a setting on your thermostat that makes the unit stay on for 10, 15, 20, 25 minutes after you reach set temp. You can change this setting by looking at your manual for the thermostat. Not sure if there is one for this thermostat but mine has one. Mine was running 15 min after set temp and making it cool down 2 degrees lower than set temp. Hope this helps.
Posted on Jun 25, 2009
  • 22 Answers
SOURCE: my furnace keeps running heat increesing 5 degrees
heat anticipator is shorted or broken. if this is the case you must replace the tstat.
Posted on Nov 24, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: furnace does not shut off
Easiest way to find out is to disconnect the thermostat or at least the red wire on the thermostat. If it stops, it's the thermostat. If it continues, you will need to disconnect the wire going to the R terminal on the control board. If it stops, it's a crossed thermostat wire. If it continues, its a problem with the control board or relay and you will need a technician.
Posted on Mar 09, 2010
SOURCE: i have a honeywell thermostat model#th6110d1005
i just called customer service for the same problem. Push the fan button, which is the MIDDLE BUTTON of the 3 bottom buttons, and the UP ARROW button at the same time, you will see the number 1 on the left of the screen. Press the bottom right button until you see the number 28 on the left, 68 should be on the right. Press the DOWN ARROW until you get to the desired temp, it won't go lower than 50. Then press ok.
Posted on Sep 25, 2010
I have the 5 day. 2 day programmable thermostat. Installed in the winter but now that it is summer air conditioner won't come on. Can you please advise?
You should always include model number in requests. More info is better. In general, there is a setting for Heat and cold on cheaper thermostats. Mine is like that. It works for heating in winter and you must switch it to "cool" for summer. I assume you do have an AC unit for summer. Who wired it up? was it ever working? Did it get installed during winter? The wiring may be wrong, there are a lot of possible ways to wire. If you are not good at that (and why would you be here if you were?) better get a tech to check it out. In the old days, Edison might send out a tech for free to advise (not fix) if there is a possibility of short (dangerous).
May 20, 2017 | Heating & Cooling
I installed my honeywell rth221b1000 this summer and got it to work with the a/c. When I switched it to heat it does not heat. The heater seems to come on but it does not heat and the fan does not run. I...
If when you turn the heat on you hear the furnace fan start up (exhaust fan) then the problem is NOT the Thermostat....need some more info on the furnace...the Wiring in the thermostat should include a Jumper wire between RH & RC if you have 4 wires and no jumper required if you have 5 wires
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
Cold air will not turn on
What you can do is you can go to any store for special like bottles that you put inside the AC unit to get cold air.
Thank You!!!!!!!!!!
Jun 23, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
81 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
