Question about kawasaki Full Suspension Mountain Bike Men
Tried to pop start in 3rd gear kfx450r atv engine will not turn
We changed oil in the kawasaki kfx450r atv,battery was dead so we charged it. after charge we tryied to roll start the atv in 3rd and4th gear but the engine would not turn over. the tires would just slide could the engine or the starter be locked up.The atv just ran the day before. The year of the atv is a 2008. And what do i do to check the engine or the starter.and where is the starter located on this bike
    New Friend:
Mine is like locked and wont turn over allmost like the starter is all pilesed up before that the bike wouldent only sometimes start on the starter or would wined out out but catch somethimes am wondering if its the starter
Posted on Jun 12, 2013
I have a 2008 kawaski KFX 450r. Been having issues with it starting. I will ride the bike a 2 o 3 days, then it wont start. Thinking it may be the stator? Battery has been tested, and is good. Battery is always kept on a trickle charger when bike is stored for long periods of time. The starter makes a loud grinding sound as well. Also thinking it could be the starter. Before I spend hundreds on parts, is there any advice?
Posted on Mar 17, 2010
I had the same problem. The compression release fell out of the exhaust cam! Its part of the cam. I replased the exhaust cam and it starts easily now. Don't forget to use a magnet to find the piece that fell off. If thats not it you siezed your motor.
Posted on Dec 19, 2008
  • 4 Answers
Kfx 450 is fuel injected
needs good battery to start
not enough info to diog
does the starter turn over
is it getting spark
or is fuel pump working
need more info
Can not figure out why my atv is not charging the battery?
Sketer, check all fuses, could be the stator..also the regulator/rectifier faulty. Google search your make and model# manual.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why my ATV battery wouldn charge the rectifier
atv not charging battery
How to diagnose and repair motorcycle charging problems
07 Can Am Renegade 800 Stator Charging System Check Removal
Apr 30, 2016 | ATVs
My yamaha wont turn on i tryed moving the gear that the starter turns and one way it moves nice and clean and the other way locks and wont move what could it be
When it "locks", that's just compression - it's normal. If you turn it so it "locks" and wait a while, you'll be able to turn it a little more before it "locks" again - that's compression leakage, again normal. If you put it into gear and rock the machine back & forth, you'll be able to see the ring gear turning, too. Normal.
So... let's back up. When this all started happening, did the starter just crank the engine slowly? DId it crank quickly but the engine didn't fire? The battery may be dead or near-dead now, in which case you'll need to charge it or jump-start it. Regardless of how it acted, there's a lot of stuff to check before we can know for sure why it wasn't starting. First... check to be sure it has plenty of good new gasoline in it.
Jul 31, 2014 | Yamaha 2004 Warrior Base
How can I get a wiring diagram for a Kawasaki KFX 450R?
get-wiring-diagram-kawasaki-kfx-450r-vkeb3uajg4eweh5dognnetyc-2-0.png here is one or you can go to kfx450hq.com good luck with your project.
Jul 22, 2014 | K and N Kawasaki Kfx450 Kfx450r K and n...
Tips on how to free up a tight bottom end on a 08 kfx450r not locked up will still run with a roll start but to tight to start of the starter? headgasket did blow and got a lot of water in the oil and got...
change oil ? water wont compress!!! prolly gallded all internal parts . at this point i would try transmission fluid. drain oil and check for metal or allum. shavings. refill w/trans fluid , remove spark plug , add tfluid in very small amt to cyl. replace plug.start briefly dont rev eng at all . let idle if it will. maybe 1 to 2 mins. shut off let complete cool down . restart again w/same fluid. same as b4. stop drain fluid . smell t.fluid if burnt or not. flush cranckcase w/new oil. hope for the best here. refill eng to proper level and p++ y. has worked for me but wasnt severe as yours sounds to be. good luck let me know if it helps or not. be sure ALL TRANS FLUID IS GONE FROM ENG. B4 new oil is put in . replace oil filter too b4 trans fluid is added and after tfluid is emptied.
Jul 14, 2014 | ATVs
94 eagle summit started to randomly die for no reason. Then it won't start rite back up rite away. I got a turn up oil change air filter changer full tank of gas belts changed. I drove after then again...
Take the battery out and have it charged. Have a shop test the battery to make sure it is ok. If it died and the battery was dead check the charging system when you get it started again. With a volt meter test across the battery with the engine running. You should have 14.2-14.5v. This indicates the system is charging. If it is in the 12-13v range it is not charging and may need an alternator.
May 29, 2014 | Cars & Trucks
Hyundia starex auto will not change from 3rd gear
may hav burn a shift solenoid--put car on a scanner--local parts place does it for free--nomerical codes will show and explained in a manual--but bfore replacin a part a more detailed scan shud b performed
Jun 15, 2013 | Hyundai Cars & Trucks
kawasaki Full Suspension Mountain Bike Men Logo
923 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Marvin
Marvin
obsteiner
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
