Question about Kenmore 24 in. 16182 / 16189 Built-in Dishwasher
Kenmore Dishwasher (Sears Canada) 665-16532200
Bought this dishwasher just under 4 years ago, brand new, no extended Wty. Never found it washed particularly well, but I am a "pre-rinser" anyways... Friends and family would mention they never have pre-rinse, and their machines do fine.... Now, after the machine is full of water, there seems to be no pressure coming out of the jets, the dishes stay dirty and greasy, the soap stays in the dispenser drawer. I have had a Sears repairman in and he says "....must need a new motor...". I had an VERY reputable local independant repairman in, and he says oftne it is the "impeller", but it all comes part and parcel with the motor. It just seems unreasonable that a higher end machine, cannot even last 4 years..... I would be happy with maybe 14 years!! Any suggestions how I might get them to help me out with the motor on a good will basis, since it is practically NEW ??
    President:
  • 1,462 Answers
4 years old is not new! you took a risk by not taking out extended warranty and it didnt come off. sorry to be unsympathetic but a fault after 4 years is not unreasonable
Posted on Mar 28, 2007
Tip
Thank you, thank you!!! A repair service that came to fix my 4 year old Kenmore...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 13, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Replacement motor arrived. Slightly different. The old motor had a proprietary kenmore electrical connection.
Sears Appliance - Dishwashers - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Dishwashers
Rating: 1 - ‎80 votes
We have ordered new wheels but the price for plastic wheels seemed a little high ....Hose came loose, water pours out and into my basement, pump slips out of slot ..... I will NOT be buying another Kenmore dishwasher when I do replace it.
Sears Appliance - Dishwashers ' Page 2 - ConsumerAffairs ...
We bought a Kenmore dishwasher from Sears a little over 1 year ago and ....Switchboard being replaced 3 times, motors and wiring being replaced they still will ....Another tech came out and said "Well they didn't program the motherboard" so ...
Kenmore Dishwasher Parts - PartSelect
www.partselect.com/Kenmore-Dishwasher-Parts.htm
Dec 22, 2015 | Kenmore Dishwashers
I bought a new bosch dishwasher less than one year ago, and it doesn't clean my dishes because the lid on the soap dispenser will not open during the cleaning cycle. Please help SAP! Thank...
Try cleaning the latch that holds the door. After a year the detergent will build up on the spring causing it not to open. If that doesn't do it call the people who you bought it off of. It should have a extended warranty for a year.
May 14, 2011 | Dishwashers
No model number can be found on my Whirlpool built-in dishwasher. It has the term "Quiet Wash" on the front. It was brand new in 1996, installed in a new home but never used until a year ago.
If there is no number on the sides of the door edges,you can try taking the kicking unit off units below dishwasher and look at base plate of dishwasher if not there then you will have to remove unit and see if there are numbers on the top sides or rear of dishwasher.
Hope this helps.
May 09, 2010 | Dishwashers
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Why wont dishwasher drain?
The 'drain hose' must placed into the sink and be free of kinks and obstruction. There is a pump that is supposed to pump the water out through the drain hose into the sink. If that pump does not activate, no water will be pumped out. I suggest yo have a repair technician trouble shoot and fit it.
Oct 03, 2009 | Dishwashers
I have a Kenmore dishwasher that will not pump water through the spray arms. It fills ok and drains fine but wont go into the wash cycle? Any idea of possible problems
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Apr 18, 2009 | Kenmore 15762 Dishwasher
Kenmore 24 in. 16182 / 16189 Built-in Dishwasher Logo
607 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
