Question about Toshiba Satellite 2400-S251 Notebook
Can't get into bios
I've tried every key combination I can think of to get into the bios, but it just keeps booting into Windows.Manual has nothing on it. It's a Toshiba Satellite 2400-S251. Only time I got into bios was taking the battery out and letting it sit for 2 months. Then it prompted me to go into bios by pressing F1, but that has no effect now.
  • fischer112 Dec 18, 2008
    Pressing F1, F2 or DEL didn't work, still goes to Windows boot. Holding down any of the keys doesn't stop it either, just get the overflow beeper.
    CRTL-ALT-DEL does get it reboot if I catch it before the Windows boot screen, but then it just continues to boot. --fischer112
    President:
  • 2,110 Answers
Try F1 OR F2 OR DEL
Posted on Dec 18, 2008
  • Sibananda Jena
    Sibananda Jena Dec 18, 2008
    OK try this
    1. Turn on computer by Holding down power button while pressing the ESC key.
    The machine will beep, then display:
    Check System, then press [F1] key.
    2. Release ESC key
    3. Press F1 key
My toshiba sat 2400 cannot connect ,maybe windows needs to be reinstalled
Posted on Jan 22, 2011
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
Apr 11, 2013 | Biostar G31-M7 TE Motherboard
First boot of Win 7. New PC build
Hi.
First of all when you are in the BIOS and have set the DVD/CD drive as the first boot device make sure you save the settings before you restart the computer as it will not remember the changes if you don't.
Make sure that the lens on the CD/DVD drive is clean and also make sure the Windows 7 install disk is clean and free of any finger prints.
make sure that you keep tapping a key when the drive spins up as sometimes people miss the "Press any key to boot from CD/DVD" message.
If you still can't get the disk to boot then try the install disk in a working PC and see if that reads the disk. If it does then the optical drive could be faulty or does not support DVD format.
Regards.
Feb 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I have tried holding the zero key while pressing the start button on my toshiba satellite, but it does nothing to bring up any recovery.
Try hitting any of the following keys:
  • F8 (should bring up the windows boot screen, and on there you should see "Repair your Computer" or something similar).
  • esc
  • del
  • f7
  • r
  • c
  • home
I believe F8 is the one you need to hit, but the others are keys I've seen to be various boot options in the bios. Note: F8 needs to be hit after the BIOS screen but before the loading windows screen.
Jul 19, 2011 | Toshiba Satellite 1415-S105 Notebook
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
I bought GM5048 from a friend. In good working order. Now I have everything hooked up & it keeps telling me Media test failure,-xe-MOF exiting boot agent-- O-bootable device-insert boot disc press any...
1. You didn't specify if you are installing Windows XP or which operating system.
I assume that you want to install Windows XP. I am not sure as to the age of this unit and if it is compatible with the above mentioned OS.
2. If you have a valid key then any Windows XP Operating disk will boot your PC unit provided you have allow the device in the bios to boot from it.
3. You will need to select the CD/dvd device to be enabled for the pc to see the boot disk. Usually selecting F12 or F1 will allow you into the BIOS setup for this.
You will need to ask your friend for the user manual to follow the bios setup procedure. I don't think there is a user manual for this model online anymore.
Oct 05, 2010 | Gateway GM5048 (6304) PC Desktop
My laptop is passing BIOS, then i get the possibility to choose my start up choise. no mather wath i choose, the sreen goes black, and a cursor appears. It does nothing anymore, even a live ubuntu cd...
Remember, there are many things you can do which will make your Windows installation as well as your laptop unstable, or even make it so it will not boot. Try to get into your bios. Different computers have different ways to get there - some have it on the screen, such as "hit delete key toenter bios" or "hit f12 to enter bios" or some other key combination. I think you enter the bios on your computer by pressing F10 repeatedly while booting. You should get to the setup screen. See if your hard drive is listed. You should see a hard drive as well as a dvd drive. If your drive is not listed, either someone has changed your setup so it is not the boot drive, or your drive may have gone bad. While you are in the setup, if it is not already the first choice, make your dvd (or cd) drive the first boot device. If it shows up, make the hard drive the second choice. Then when you boot, the Ubuntu should load. Try not to make any other changes, as you can make your laptop unuseable.
Aug 22, 2010 | HP Compaq nx9010
Can not get laptop to enter bios
On many of the MPC laptops, the bios can be brought up at boot by pressing the F2 key. Generally, while booting, the screen will show you the button to push. Here are some more of the most used key combinations you can also try. On our mpc support site, there is no manual available yet for this model. Also, mpc laptops have the capability to lock out the bios at users request so many used models obtained cannot be changed. We'll have a new support site for mpc up this summer. Details at mpcsupport@cox.net
Most of the time during boot-up the key (combination) will be shown. If it is not, then you could try the following key combinations:
  • Del
  • F1
  • F2
  • F10
  • Ins
  • Esc
  • Ctrl+Alt+Esc
  • Ctrl+Alt+Enter
  • Ctrl+Alt+Ins after Ctrl+Alt+Del
  • Ctrl+Ins
  • Ctrl+Alt+S
  • Ctrl+S
  • Ctrl+Shift+Esc
  • Shift+Ctrl+Alt + Num Pad Del
  • Ctrl+Esc
  • Ctrl+Alt and +
Dec 25, 2008 | MPC Computers TransPort T3000 Notebook
BIOS on Toshiba Satellite 320
press f2 or f8 (function keys )
in that cmos settings ---goto advanced settings ---boot device ---in that highlight cd drive---then save and exit
Nov 26, 2008 | Computers & Internet
Access BIOS
what computer brand and model is it ?
Robert
Sep 01, 2008 | IBM NetVista PC Desktop
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
Toshiba Satellite 2400-S251 Notebook Logo
172 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
