Want to reset the v-chip on my 2001orion tv model # 1933
    Top Expert:
  • Televison & ... Master
  • 76,125 Answers
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Posted on Aug 13, 2012
SOURCE:
Tip
Reset Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Televison & Video
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Imy lcd tv digital lab rimot control lost i need reblase model dltdv1933
Google the model number of the unit with "remote" to try to locate one or call whoever made the set.
May 01, 2012 | Televison & Video
What is the code for the sky remote for my Acoustic solution 1933 lcd tv
Try the one of the following:
065, 0206, 0649
Depending on your exact model number, it should be one of them. If none of them works, send a message back with your exact model number and I'll look into it.
Apr 06, 2011 | Televison & Video
Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Apr 29, 2010 | Mitsubishi WS-48315 48" Rear Projection...
I need a manual for my Ameritech cordless phone Model 1933
I have the manual for the Ameritech phone Model 1933. I have scanned it and I can email it to you, if you provide an email address I can send it to.
I don't know how to attach it on this website (this site is new to me).
Mar 04, 2010 | Alert Caller ID with Internet Answering...
V-chip reset
I cannot find any way to reset it. You might contact the manufacturer.
Oct 06, 2008 | Durabrand DWT2704 TV
I have a toshiba tv model:19a21 and i want to unlock the v-chip. i did not activate the v-chip i was like that when i bought the tv what can i do to reset it
To reset the V-Chip on the Toshiba 19A21:
Hold the volume down on the TV - at the same time, press the number 1 on the remote. The TV will turn off and reset everything.
Jun 22, 2008 | Toshiba Televison & Video
V-chip code forgotten
I found this to work on my Toshiba TV/VHS combo MV19M4 after trying others suggestions that had worked on similar models but nothing worked on mine. Maybe it will work for yours. Follow these steps:
1: Unplug the TV for 1 minute then plug it back in.
2: In the menu select "TV Set Up".
3: Move the blinking block to beside "V-CHIP Set" BUT DO NOT SELECT IT.
4: Hold in the number 1 button on the remote.
5: Hold in the volume down button on the TV.
Your TV will turn off. Give it a few seconds to reset itself and then turn it back on and you will have to completely reprogram your settings. When you go to the V-CHIP settings it will ask for your new code.
- Jenny
Nov 01, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Ekse
