This tv has power when i turn it on but it shuts of after a second.
To diagnosed where the cause came from, first place to be done disconnect the connector that supply to the inverter board for screen back light which may have shorted line that can cause of suddenly shut off. then tried to turn on the tv with out the ballast board, if the supply from the power supply get stable and the indicator stay with out blinking that was mean the ballast board could be bad. by the way you must replaced first bulged capacitor at the power supply board. hope this can helped good luck.
SOURCE: TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
This could be a main board or power board issue. replacing main board and/or power board should resolve this problem.
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
SOURCE: when i turn tv on screen says no signal then tv
First unplug the unit, disconnect all the inputs(cable, video, etc.) and then plug it in and turn it on naked. Let me know if the symptoms still there to assist you further.
Jdvillanueva
