Question about Vitamix 5000 Work Top Blender
Blade turns with difficulty
The blade for my wet container is difficult to rotate. I've used my vita-mixer regularly for the seven years. I've been using my dry container until I can resolve this problem. There is a tool that can remove the bottom part for inspection. Any suggestions will be appreciated.
    President:
  • 1,618 Answers
Check the blade assembly it may be worn out.
Posted on Mar 26, 2009
Where can I find a motor
Vitamix says they will fix units up to 20 years old or so????
check here:
Contact Us Customer Service Vitamix
Don't know about 30-40 years old????
good Luck
Feb 23, 2014 | Vitamix Vita-mix 3600 / 4000 Handle For...
Loosened blades on a vitamix 3600 stainless steel container
If what you can't see in your device, namely the motor assembly, it may be that the assembly is one of those not designed to be taken apart and that it is wearing out. If so, that could be the cause of the looseness you are experiencing. It may be unrepairable or more costly to fix than to replace. Twenty plus years is a good run for almost any mechanical device.
Jan 02, 2014 | Vitamix Vita-mix Super 3600 Stainless...
Have had my Vita-mix 5000 for several years with no problems. Now, it leaks oily, black liquid around the base, and jerks erratically when the blender is set on the lowest setting (#1 of 10)/variable.
Is it getting hot when you operate it? If you run a mixer for a long
time, the motor will get very warm. On the older units, when the
motor overheats, the various parts of the motor and its container
may start to melt. Mixer motors are not designed to last forever and
a replacement motor may be available from the manufacturer.
Another way is to purchase another similar mixer as you can on
eBay and swap parts.
Aug 21, 2011 | Vitamix 5000 Work Top Blender
Motor base is working and container jar base turns by hand but won't work together to spin blades
Just fixed my blender. Motor was working fine, but the bladea wouldn't turn. I removed the blade piece from the base and tried moving the blades by hand and they wouldn't turn. So, I lubricated the blade at the location where it's supposed to rotate. I kept trying to move the blades by hand and gradually they started to loosen up. All fixed!!! I guess they get stuck after a few years of use.
Aug 13, 2010 | Back to Basics Smoothie Elite Work Top...
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
1,045 people viewed this question
Top Vitamix Blenders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
