Question about Panasonic PT-44LCX65 Television
Red light came on and said I need to replace the bulb? Panasonic said I could do it myself. How much does this cost to have repaired and is it worth it? The Tv is only 3 years old
  • ladyblue14 Dec 18, 2008
    Thanks alot. I appreciate your help.
  • 2,336 Answers
Click here to find a lamp for your TV and use the housing from the broken lamp or you can buy the lamp that comes with the housing from this website.
If you have the user's guide, the instructions on how to replace the lamp can be found on page # 67. Here is the user's guide if you do not have it.
Good Luck.
Posted on Dec 18, 2008
Tv wont turn on
old technology, dump it. My work place at the airport just installed a 72" Samsung Ultra High Definition 4K flat television. Easily worth the $6,000 it cost.
Jun 17, 2017 | LG 62SX4D 62" Television
I have a Panasonic 42"/46"/50" Class 1080p Plasma
This usually is a result of a failing power supply or any of the SOS circuit boards. Power supply's and boards are expensive to replace and in most cases not worth the cost to have repaired if you are out of warranty. However this is a known issue for Panasonic and I have seem them repair your model sets at no cost. So it is worth giving Panasonic a call and see if they will fix this for you. If they agree to fix it they will send a tech to your home for repairs.
Mar 02, 2011 | Panasonic Televison & Video
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I had been getting the bulb life low message so after it went completly went out i replaced the bulb. my tv was absolutely fine before now it has a red haze on the top of the screen and it was not staying...
Power supply for a red haze problem? Doesn't sound like a powersupply issue. If its a red haze that Im thinking aobut, you might as well buy a new set. It'll be a little too costly to fix.
When it was shutting down, what was the red light blinking before it paused then repeated?
Dec 29, 2009 | Sony KDF-50E2000 50" HDTV
I heard a pop in the TV and then the screen went red. I can still hear it and watch it but everything is red. Is it a bulb that needs replacing? If not, what is it? Can I do it myself or will I have to...
Several failures can cause a red picture but it sounds like if you are connected from the source with component video cables(red,blue,green)you may just have a bad cable,but you may have had a blue and/ or green projection gun failure,which would cause the red gun to over power the other colors(blue/green), if this is the case definently not worth the cost to repair, you have to replace all three guns at the same time costing $500+ to repair, invest that towards a nice new LCD panel TV. Good luck !
Nov 26, 2009 | Akai PT5492S 54" Rear Projection...
Replaced bulb - no picture - blue dim light
Ur CRT need a rejuvenation,it a messy job.
It cost u the big screen repair shop about $300 dallors.
Sep 02, 2009 | Televison & Video
Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-44LCX65 Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
