Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
Problem when turning monitor off
I am writing to ask for help regarding my parents' computer monitor. Unfortunately, they arent very familiar (confident) with computers, so I am trying to help them with their problem. I have been away out of the country for several years and also not too familiar with the new LCD monitors, flat screen, etc. They have always left the computer on. To be honest, I dont know if that is a good thing or bad thing nowadays. They have had the monitor for around 2 years now. So, you can assume that the computer has nearly always been on, even though it is used very little. Anyway, to get to the problem, I have told them (again I am not very familiar with these kind of monitors) that maybe they should be turning their monitor off every once in a while. So they have started doing this. We have noticed that the monitor is having problems rebooting when we turn it back on. It starts making weird noises (kind of like a squeeking noise) and the picture is just barely seen on the monitor (the screen is very dark). It continues making the weird squeeking noises for around an hour and finally makes kind of like a rebooting noise and the regular screen (as it should be) comes on. Other than rebooting the monitor after turning it back on, they have had zero problems with the computer. I have been researching on this trying to study up on LCD monitors the past several days and have found that it is recommended to go with a "blank screen" screensaver and to put the option of turning off the monitor automatically after a several hours of inactivity. I dont know understand, however, why the monitor has trouble rebooting after being turned off for several hours, though. Maybe it is normal? or the monitor should be treated in another form? If you can help at all with this problem, I would appreciate it. Thank you!
  • dddy170 Jun 21, 2008
    The power light on my moniter just keeps blinking on and off and the picture never comes on...
    Genius:
  • 1,970 Answers
Mcdevito75 here LCD, or liquid Crystal display, chances are the crackling is the inside liquid display trying to capture the in comming electricity to make a display picture. Remember even an LCD is nothing more than a light bulb, a very intricate light bulb but a light bulb, and you have light bulbs burn out when you put them on and almost never as the are on burning. Turning the monitor itself off won"t really save electricity or the monitor itself as, when you shut down the computer from Start (left side of screen) the monitors screen saver comes on for 10--20 minutes then goes off, at this point the electricity is at the monitors on/off switch and not going thru the monitor at all. If you turn the monitor off at it"s on/off switch, the sudden jump of electricity to the monitor from it"s on/off switch could hurt it, or even the switch. I have a friend who turns off the monitor also and that friend had a bad monitor in 3 years. I never turn my monitor off just the computer itself. I'd speak with a Radio Shack, Staples, Best Buy ETC. for more advise. Me I;d say leave the monitor on. Hope this helps.
Posted on Jul 14, 2010
Viewsonic va2431wm monitor, lCDd slowly fade from normal screen to white. The monitor turns on but only get white screen, no color. Open monitor, nor bad capacitors. Why no picture?
Hello, unfortunately this is usually due to hardware problem, In this specific situation it is most likely the problem with lcd panel itself (electronic on panel). Sometimes it can work after the units becomes cold (not working for some time) and you power it on again.
Anyway if you are not familiar with electronics , please visit proper service center, due to the high voltage inside.
Hope this helps.
Oct 21, 2014 | ViewSonic Va2431wm LCD Monitor
A green vertical line appears on left side at with signal or without signal
Hi there, unfortunately bad news it is panel defect. The only solutions should be to replace it. If you are not familiar with electronics please do find proper service personal for that.
Thanks.
Mar 08, 2014 | ViewSonic VX2235wm LCD Monitor
How to write a research and essay paper
Choose a topic that will highlight you, Don't try to cover too many topics & don't rely on phrases or ideas that people have used many times before. Ask a Teacher or Parent to Proofread or if you need online help for writing your research & essay paper, I can suggest you GetMyEssay.
Feb 11, 2014 | Computers & Internet
Hello I have a Angelcare baby monitor model ac1100 and have had it 1& half years it hasn't put a foot wrong and all of a sudden the tv monitor side of it is not working properly! It stays a blue screen and...
If you can only see two lines appearing on the screen this may indicate that the parent unit is searching for a signal from its partner and cannot locate one. Check that the nursery unit has fresh batteries and is switched on. If all ok with the nursery unit you may need to "re-pair" the two units together as per instructions. Note that the maximum distance between the Parent Unit and the Nursery Unit is approx. 100 metres indoors. In reality the Signal Strength Indicator on the parent unit should show the strength of signal between the Parent Unit and Nursery Unit. The Out of Range Indicator should alarm when the two units have lost connection and the Out of Range Icon will be visible in the Parent Unit screen. However these units sometimes require a "re-pairing" exercise to get them to communicate with each other again. Ensure both units have fresh batteries.
HOW TO RECONNECT THE PARENT AND NURSERY UNIT
In the unlikely event that the connection between the Nursery Unit and the Parents Unit is completely lost, please follow these steps to restore the connection:
1. Turn both the Parents Unit and the Nursery Unit OFF
2. Turn the Nursery Unit ON
3. Press and release the left wing 4 times. The nightlight will fl ash.
4. Turn the Parent Unit ON. A blue screen will appear with the NO SIGNAL icon in the Parent Unit Settings Bar
5. While pressing the TALK BACK button on the right hand side of the Parent Unit, press and release the POWER button on the left hand side of the Parent Unit
6. If successful, the video capture will appear on the Parent Unit's screen again. The connection was successfully restored
Jan 18, 2014 | Baby Gear
I cant remember my pin number for parental control on my wii
  • Turn on your NintendoWii and enter the Settings Menu.
    Click on ParentalControls.
    It will ask you foryour Pin Number but just click "I Forgot".
    Now it will ask youfor the answer to a security question, just click "I Forgot" once again.
    You will now see aconfirmation code on the screen, this is what you should give to Nintendo whenyou phoneup. But we arenot going to do that.
    Head over to: http://wii.marcansoft.com/parental.psp
    Enter the confirmationcode which the Wii is showing into the box on the site.
    Make sure the date isright and click "Get Reset Code".
    You should now have an unlock code to enter in the Wii.
May 25, 2011 | Video Game Consoles & Games
I request information about angel care AC401 We have build this product but we are not able to work it. When we turn on the unit parent the digital screen shown "--" and the nursery unit icon...
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
press and hold the little round blue light at the top for about 5 second until it beeps.
the parent unit waits for the signal then pairs.
Nov 08, 2010 | Angelcare Baby Movement and Sound Monitor...
I need help getting my computer of the blue screen
Hi!
In order to solve your problem I have to let you run several checklists with your help. Before that let me know whether you are a familiar user with the computers, operating systems and hardware. And also let me know whether you are familiar with electronic diagnosis tools.
Describe your last activity with the machine.
Do you have a Laptop or a Desktop? Which Operating system do you use? Have you performed installations? removals of Software applications? Hardware installations? Have you received errors during the last session? Have your machine infected with a virus?
Please answer these simple questions (Ignore the Software usage problems if you are not familiar with them. I ll ask during the process).
Because if you are not familiar with them I need to give you more detailed solutions.
If you are a familiar user with machines and Operating systems:
How to read the error message associated with the blue screen
  1. Power up your machine.
  2. If you use a Desktop PC, Tap F8 key several times BEFORE BOOTING WINDOWS Operating System
  3. You will be presented with a menu.
  4. Choose "Disable Automatic Restart on a System Failure" option.
  5. You have to use Keyboard keys to scroll the menu.
  6. Press Enter key after the selection.
  7. Now use a Paper and a Pen and Write Down the Error Message which is on the Monitor with the Blue Screen.
  8. Add to the next reply.
Thank you! -Lasitha
Sep 03, 2010 | Computers & Internet
Monitor display
Appreciate the direct "Ask Me"
Unfortunately, an HCL HCM782M monitor is an unknown model. However, on similar instances and occurrence of this problem, it would seem that the controls are damp. Specifically, it would be the internal contacts of the buttons. Pls check if you can dis-assemble, remove the board/control/buttons and perform cleaning. Pls pay particular attention to the rubber pads or the small buttons themselves. if I may ask, any recent continuous rain? If yes, this may have contributed or caused your problem.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Computers & Internet
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
