Question about Bose Lifestyle 12 System
My system (bose lifestyle 12) hoas no sound at all. I checked all speaker connections they seem to be OK. Please help.
SOURCE: Bose Cube Speakers separated
Ok…
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
Tools:
small, thin, flat-head screwdriver
large pliers
C-clamp
Instructions:
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Posted on May 17, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: The display stopped working on my Bose Lifestyle
i did have encounter the same problem!!!! what i did was have the whole capacitor replace ! I didn't bother to have them check beside its will cost you less than $10 this is how a capacitor will look like http://www.allproducts.com/manufacture97/qiyu/product1.jpg . check the ( + )positive ( - )nagative by marking either one on the PCB board before you proceed! very important! good luck
Posted on Dec 06, 2009
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Mar 04, 2011 | Bose Lifestyle 12 System
DVD and Menu screen color settings are not right. We recently had the local Bose store set up our Lifestyle 48 system and all was well but recently the screeen color, when in menu mode, has changed from...
Jason.... there seems to be a connectivity issue and i could not see any of your messages in the chat box.......
for reconnecting the unit... please refer to this link below
http://products.bose.com/pdf/customer_service/owners/ls18ii_ls28ii_ls38_ls48_install.pdf
the Surround speaker cables have orange RCA connectors at one end and speaker plugs
at the other end with L (left) or R (right) markings
Jul 31, 2010 | Bose Lifestyle 48 System
My Bose Lifestyle 12 - No Sound
What sound are you putting into the system? Have you checked that the audio you're putting into the system works into some other device? Have you checked that you have the correct input device selected?
If you have checked that the audio going into the system is working properly and you have the correct input device selected then yes, audio in but nothing out = something is broken inside.
Nov 01, 2017 | Bose Lifestyle 12 System
No sound coming from speakers , I have a bose LS-12, i could hear the cd spinning but no sound even in FM Mode. HELP! !
To troubleshoot:
- check connection of player to speakers
- check if the volume is at minimum level or mute
- check if player is in CD player mode
Jan 03, 2010 | Bose Lifestyle 12 System
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
No Sound from the speakers
sounds like the amp went , you will need to call bose
Dec 09, 2008 | Bose Lifestyle 12 System
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
Bose lifestyle 12
cheak your modes ok not 2 ch sterio are u use prologic adjust rear level also up
Mar 15, 2008 | Bose Lifestyle 12 System
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
Bose Lifestyle 12 System Logo
64 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
