Question about Dacor MCS130 Millennia Electric Single Oven
Dacor CPS 130 oven will not heat
I read the suggestion to reset the thermostat behind the door latch but this model does not seem to be made that way. Any other suggestions?
  • 78 Answers
This model actually made this way. Sometime you can not see the thermostat because of the bracket in front of the door latch. When you remove grill panel under control panel you gonna see this bracket. It pulls out very easy. Behind the door latch you will see thermostat with red button on the middle. Before resetting this button make sure you disconnect electricity.
Posted on Dec 18, 2008
Does not work after self cleaning.
Behind the door latch assembly there is a thermostat with a reset button on top.
When its tripped everything will appear to work, but just no heat in the oven.
Use a wooden spoon handle to reach behind the oven door latch and push down on the button.
Your oven should work after this point.
Oct 27, 2008 | Dacor MCS130 Millennia Electric Single...
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
After I cleaned my ovens the top one doesn't heat anymore. I was told that the circuit fuse button has to be reset. We can't locate it. Can you please help? The model umber is: Thermador SCD302TP
Welcome to FixYa.
To address your post, looking for an over-temp cut-out tripped. Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the lower door ( just below upper door) next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...as shown here,
If indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Other than that if you call in a pro, I'd suggest you be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Hope that answers your question and gets you back up and operating. Good luck.
Regards,
Macmarkus :)
May 29, 2011 | Thermador SC302T Electric Double Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
0ven temperature is 150 degrees less than the desired setting. I have replaced the senser.
HI. This unit is equipped with a thermostat. it is located just behind the door latch mechanism. i would test the operational value of this thermostat. This may be the issue here. I would also inspect the wire harness that links the sensor to the actual control board. If the wiring is worn, or the contacts damaged, this will interfere with the resistance transfer, during the heating cycle, in return, producing false readings.
Thermostat part number 74008265
Oct 16, 2009 | Maytag MEW5530D Electric Single Oven
DACOR IS A PEICE ****
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
Jul 01, 2009 | Dacor ECD230 Epicure Electric Double Oven
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor MCS130 Millennia Electric Single Oven Logo
585 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
