Question about Philips DVP5140 DVD Player
I need a motor assembly for a philips dvd player
I've already taken apart the player to see what was happening and i know it's not spinning the disc, the lens does try to read the disc though. I've been trying to find the motor assembly for a while now and can't seem to find anywhere that sells it.
Try partstore.com
Posted on Jun 15, 2007
I used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Posted on Mar 27, 2007
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
Apr 13, 2012 | Philips PET741 Portable DVD Player
Tip
DVD PLAYER REPAIR (NO DISC ERROR)
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
Jdvillanueva
on Apr 18, 2011 | Bose 3 2 1 GSX System
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
Our Philips HTS3400 DVD player is not working. When inserting a disc, it displays "No Disc". Any suggestions?
seems to be an issue with this model, i cant play any discs, the sound is only coming from the left rear speaker and the sub, the system shuts off every half hour due to overheating...needless to say the system sucks...didnt last long...im very tech savvy and still couldnt figure out why all of this was happening.
im looking at samsung now...everything else i have is samsung and love it.
Dec 31, 2009 | Philips HTS3400/37B System
My dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Jul 03, 2009 | Philips DVP642 DVD Player
Won't accept DVD's
HI, this will happen when the lens assembly is damaged and it will need to be replaced. you can confirm by using a lens cleaner. If the system starts to read as normal after cleaning the lens with a cleaning disc, the problem will be solved but, if the problem still exist after the cleansing, you will need to replace the lens assembly. it has failed.
Most of the time, the load motor will fail and this is a integrate part of the Assembly in most cases.
May 21, 2009 | Philips Televison & Video
Magnavox dp100mw8b will not read any discs i put in. be it brandnew discs, scratched discs, or burnt discs. It worked two days ago and now nothing. I've already cleaned it, now what? this is the second one...
The lens pickup is damaged and must be replaced. often the soldering joints on wiring to lens pickup are broken, or the lens is scratched. The unit must be taken apart and fixed by a technician.
Apr 03, 2009 | Philips Magnavox MPD845
CyberHome DVR 1200
Main drive motor that spins the dvd replace with generic, when the motor gets old contacts get
corroded or woren out, ive taken apart and cleand sucessfully for a nother year on the motor.
or purchas another, the dvd must spin fast at the start, ive owend 3 of these pups for about 7
years. its the drve moter the lasers are good and strong.
Mar 01, 2009 | Cyberhome CH-DVD 300 DVD Player
Cdn36 pbm
Does it make this noise only while playing a disc? or is it when it opens and closes.
If it happens while playing a disc, it could be the spindle motor or something rubbing on the disc while it is spinning. Since nothing is supposed to be rubbing on the disc, it would need to be taken apart and looked at while it is spinning to see what that is.
Let me know if I can help you any more,
Good luck,
Dave
Jun 28, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
Philips DVP5140 DVD Player Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
