Question about Goodman CKL24AR24 Air Conditioner
In AUTO; blower won't come on when i turn heater/AC on.
I have a york 2 stage heater; when i turn the heater on in AUTO the blower won't come on. only when i switfch the fan to ON and then turn the heater on then it works. but then the blower is always on.
what could be the problem?
  • 24 Answers
Most likely the heating speed relay on your furnaces IFC board has failed.Unfortunately the entire IFC must be replaced to repair this. you are in need of a professional service tech. The same control handles the blower fan, ignition system and safeties. Not a do-it-yourself repair as wires in the wrong place could cost you a house.
Posted on Dec 18, 2008
York Diamond 80, controller is blinking Code 3 (Pressure switch stuck open).
sounds like u nee a new pressure switch. check 1\4 inch tubing going to pressure switch, remove it make sure no condesation in it., blower will only come on once flame is establised, ventor motor comes on closes pressure switch, brings on ignitor then gas the blower, make sure no blockage in vent pipe
Dec 28, 2015 | Heating & Cooling
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
Heater won't turn on
CHECK AC AND HEATER CONTROL FUSE. IF FUSE OKAY CHECK BLOWER SEE IF POWER GOING TO BLOWER MOTOR IF YES BLOWER MOTOR MORE LIKELY FAULTY.IF NO POWER GOING TO BLOWER MOTOR CHECK BLOWER MOTOR FUSE ANDRELAY.
Oct 28, 2011 | 2000 Kia Spectra
Newly installed York Horizontal 96%+ 2 Stage FAU, not lighting, no fan/ blower, green blinking ststus light on control board
I would say your motherboard is out. If it is still under warranty, then you can just call York. If it isn't it is a little pricey to get fixed.
Mar 26, 2011 | Heating & Cooling
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
The fan blower stays on after I have turned off the AC & heater.
You will need to replace the Final stage resistor. You can find the part at your dealer, or get it at other parts stores. This is a common issue.
Dec 16, 2009 | 2002 BMW 5 Series
York diamond 80 heater does not fire up
Mostly likely the problem is in the pressure switch that tells the board that the blower started and it is okay to fire the burner. The pressure switch is usually a 2" or so round thing about 1" thick, it will have one or two tubes coming out of it that go to the blower or heat exchanger. Make sure that the tube is not cracked or that it has not come off at either end.
The pressure switch can be jumped out to check out if that is the problem, but you need to jump it out after the cycle has started and the switch needs to open after a cycle for the heater to refire again, so that fix would be very temporary. But it may tell you for sure what the problem is.
Nov 14, 2009 | Heating & Cooling
INSTALLATION MANUAL FOR PV9C YORK FURNACE
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
Jun 10, 2009 | Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
800 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
