Question about Hunter 52" Ceiling Fan With Light And Remote Control
The remote reversed
The remote controls that are suppose to turn on the light turn on the fan and the fan controls turn on the light why is this doing this?
    Scholar:
  • 75 Answers
Who ever hooked it up got the hot wires crossed between those two things. That is a quick fix, but has to be done at the base of the fan.
Posted on Dec 21, 2008
How do I get the fan to work using the remote ? All buttons (even the fan buttons) only operate the light, and only the upper light at that. Battery was low. Thought that was the issue, replaced with
First of all, that's a low-end fan made for Home Depot only! Did the remote come with the fan or was it an add-on remote. If there are any pull chains on the fan & light, then it was an add-on remote. If there is a reverse switch on the fan, then the reverse on the remote transmitter will not work. Probably need a new receiver.
May 05, 2014 | Dryers
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
How can i switch my fan to reverse? Its a Hampton
There is usually a slide switch on the side below the motor.
I don't believe any of them reverse from the remote control.
Nov 26, 2009 | Hunter 52" Ceiling Fan With Light And...
My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Jan 23, 2009 | Minka -Aire Brushed Nickel Remote Control...
Reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Nov 20, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay w/ remote and will not reverse.
To eliminate this problem and any humming noise, remove any wall switch that turns off and on the fan, just remove the switch from the line and use the remote to operate the fan.
Jul 29, 2008 | Universal Remote Control Hampton Bay...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
48 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
