Question about Kitchen Ranges
My whirlpool oven electronic pad flashing f3eo
What is f3eo My oven has the same error code F3EO. What does it mean and how do I fix it?
  • 8,197 Answers
The error code E0 F3 indicates that the oven temperature sensor in your range is open. This error code can also mean that the electronic oven control in your range has failed. Disconnect the electricity to your range for 2-3 minutes. This will reset your control if it is just confused.
If the error code persists someone needs to access the back of the electronic oven control and read the resistance of the oven temperature sensor. The sensor is connected to terminals P3-5 and P3-6 on the electronic oven control by two violet wires. The sensor should read around 1100 ohms at 70 degrees
If the sensor reads more than 100 ohms more or less than 1100 it is defective. If the sensor reads within 100 ohms of 1100, the electronic oven control has failed and will need to be replaced.
Posted on Dec 18, 2008
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Sep 27, 2014 | Whirlpool RBS275PD Electric Single Oven
My oven..whirlpool model...has F1 in the display window. What does this mean?
F1 error code usually means that either the touch pad or the clock (ERC) is bad. It's simple if your model incorporates both as a single assembly - replace the clock/touch pad, problem's solved. But, when the touch pad is a separate component from the clock, how do you tell which of the two has failed, without having to replace both? Well, we have a simple test that can show you whether it's the clock (ERC) or the touch pad (membrane switch) that needs to be replaced. The test is available on the error code page right below the list of brands.
Solve it with replace electronic oven control (also called EOC or clock).
Hope helps.
May 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
When I try and Bake or Broil the oven beeps and gives a fault code of F3EO
HI. Generally, this will be the cause of a failed oven temp sensor. If your unit's orientation is doubled, the top oven sensor will be the culprit. Some model will incorporate a sensor fuse at the wiring harness. Check the fuse, if equipped, for continuity. If the fuse is bad, replace it. If the fuse is ok, replace the oven temp sensor.
F3E0 - Failed oven temp sensor(top sensor if double oven)
Mar 01, 2010 | Whirlpool Ovens
I'm getting the codes E6 and F2 on my Whirlpool double oven. It won't turn on--help!
HI. This code is in reference to the control sector. There seems to be a malfunction that has been detected within the touch/key pad assembly. Use the procedure to isolate the damage.
Jan 08, 2010 | Whirlpool RBD305PD Electric Double Oven
It seems like my oven gets overheated and then it beeps with a code on it F3EO?
How do you know your oven is overheating? what indications are given that it is overheated/ i ask this beacuse the error code f3OE may not mean the same on each model and you do not say what brand or model you have, also on some models this code means control board failure which is not necessarily due to overheating. If you look in the back of your range, there maybe a paper or plastic envelope pocket with a tech diagram paper; this usually has the error code list on it and it iwill guide you as to the problem. Sometimes the pocket and diagram are located near the bottom of the range in the back (slightly under the unit). Goodluck, Macgivor
Nov 12, 2009 | Kitchen Ranges
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
F3EO error message
Replace the oven temperature sensor.
Mar 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
I have Whirlpool Gas Range Model SF315PEGW 5. The bake function will not work and appears to through a code i.e., F3EO. Can you tell me what to replace?
will the ignitor glow if it does and its dim the ignitor needs to be replaced if not the control board needs to be replaced
Aug 04, 2008 | Whirlpool Kitchen Ranges
Kitchen Ranges Logo
2,746 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
