Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Upgrading the motherboard
Is there a program which will allow me to change the MAC address in the BIOS, since I have a NIC locked program and I want to upgrade my motherboard
  • Anonymous Dec 25, 2008
    sound not ditect
    Sergeant:
  • 192 Answers
There is no way to change the MAC address, but you can make Windows tell the system it has a different address that might fool your other program. Follow the instructions below.
Change the MAC address in Windows
  1. Go to Start -> Control Panel. Double click on Network Connections (inside Network and Internet Connections category in Windows XP). The, right click on the active network connection with network adapter that you want to change the MAC address (normally Local Area Network or Wireless Network Connection) and click on Properties. Above steps work in Windows XP, Windows 2000 and Windows Server 2003 . For Windows Vista, access to NIC’s properties is from Control Panel -> Network and Internet -> Network and Sharing Center -> Manage Network Connections.
    Alternatively, if you already know which network adapter that’s responsible for your network or Internet connection, go to Device Manager and open the properties dialog by double click on the NIC itself.
  2. In the General tab, click on the Configure button.
  3. Click on Advanced tab.
  4. In the Property section, select and highlight Network Address or Locally Administered Address.
  5. To the right, “Not Present” radio button is by default selected as value. Change the value by clicking on radio button for Value:, and then type in a new MAC address to assign to the NIC. Upgrading the motherboard - change-mac-address.jpg The MAC address consists of 6 pairs of numbers (0 - 9) and characters (A - F) combination. For example, 88-17-E8-90-E2-0A. When entering the new MAC value, omit the dash (-), for example 8817E890E20A.
  6. Click OK when done.
  7. To verify the change of MAC address, go to command prompt, then type in one of the following commands: ipconfig /all
    net config rdr
  8. Reboot the computer if successful to make the change effective.
Posted on Jan 10, 2009
How to change my mac address
Your MAC address (physical address) is baked into your NIC (network interface card). Your wireless NIC will have it's own mac from your wired NIC.
To change it you would need to replace the NIC itself. You can, as an alternative, spoof your MAC address with programs. It basically intercepts all the frames and swaps out your real MAC for your spoofed MAC.
If your using Linux, it should already be installed, from a terminal just type macchanger.
For windows you would need to download a program. This is a decent one for Windows.
http://www.technitium.com/tmac/index.html
Jan 26, 2013 | Linksys Wireless-G Broadband Router
Tip
How to find your MAC address using MS-DOS
The MAC address is the physical address your computer's Ethernet card or network interface card (NIC) uses to identify itself to other computers and devices on your network. There are different ways to find your Ethernet card's MAC address, depending on what operating system and programs you have installed. Since most Windows-based computers have access to the MS-DOS command prompt, using DOS to find your MAC address is one standard way to do it.
There are a couple of different tools you can use in MS-DOS to find your MAC address. All of them requiring opening a command prompt window, which you can do by typing "cmd" into the Run bar on the Start menu (or in Windows Vista or 7, you can type it into the Search bar instead).
- Getmac
Getmac is a utility that is included on Windows Vista computers and on newer Windows XP systems. Typing "getmac" by itself on a command line will return the MAC addresses of any NICs that you have installed in your computer. (If you have an Ethernet NIC and a wireless NIC, for example, Getmac will list the MAC addresses for both of them.)
- Ipconfig
Ipconfig is a command that will display your IP address if you are currently connected to a network. However, by adding the "/all" switch to it, you can also see your MAC address, as well as many other configuration settings. Type "ipconfig /all" and look for the line labeled "Physical Address." If you have more than one NIC, the MAC address for each NIC will be displayed separately.
on Oct 04, 2010 | Microsoft MSDOS 6 Upgrade Operating System
Mac adress lost
Makes no sense. It's part of the NIC and can not be changed. That's why it's referred to as the Physical Address.
Best guess is the NIC is bad.
Sep 28, 2012 | ASUS P5VD2-MX Motherboard
Change mac address of on-board nVidia NIC
Hello, if you go onto properties of your NIC, click 'advanced' , go down to 'locally administered address' ; this is the bit where you can enter your own mac address. See this page or google 'locally administered address'http://www.javvin.com/networkingterms/LAA.html
regards,nicam49
May 09, 2012 | Computers & Internet
Problem connecting to WIFI
If you have changed the motherboard then maybe without knowing it you would have changed the MAC address of the NIC. If your router has MAC ADDRESS FILTERING/LOCKING then you will need to connect to your router with a network cable and then add you new MAC address to its filtering table MArk
Aug 22, 2009 | Dell XPS M1210 8x DVD+RW / CDRW Dual Layer...
Lost wireless internet to our MAC OSX 10.5 Resetting ISP didn't help. Running Network diagnostics didn't help. Our ISP, Telus says it isn't their problem. Wireless is working on our non-MAC computer. It...
Did this occur after an OS update was installed? There's some history of dropped connections due to Mac updates...Check the Dlink site for firmware upgrades for your router, and install them, and see if that fixes it...
Aug 18, 2009 | Computers & Internet
NetGear WGR614 -Installation Problem on Windows Vista PC
Please make sure that you have the NIC enabled and on the computer and set to automatic settings for IP address. Now follow the steps below to reset and reconfigure the router:
Reset:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 18, 2009 | NetGear WGR614 Router
New NETGEAR router. Trying to Itouch to sign on with WPA2. Can' find internet.
Tap Settings > General > About then scroll down to Wi-Fi Address, write down the MAC address. Switch your router to MAC address filtering so that a password is not needed, but it will only let the devices whose MAC addresses that you enter connect to your router.
You will have to do the same for your computers as well.
If using a PC. Goto the start menu at the bottom, and select RUN, then type CMD (enter)
type: ipconfig /all
You will see the mac address that you NIC or Wireless card has. Enter that in the mac address security as well.
If using a MAC, goto the top left of your screen, click the apple logo, about this mac, more info, goto locations, enter your airport wireless card and or nic Mac.
This is a more secure way to do your security since so many programs can crack wireless wpa and wep these days.
Jun 24, 2009 | Apple iPod touch
I nedd bios upgrade for my laptop clevo m220s
It seems it is a product of SiS. Visit http://www.sis.com.tw and search the BIOS upgrade in the download or support section. If SIS has launched any upgrade for your product, it will be available there. (ehteshamhusain@gmail.com)
Apr 04, 2009 | Computers & Internet
Bios Upgrading problem
to completely change out the BIOS chip itself from the motherboard and replace it would cost you the same as just buying a new motherboard. it would be cheaper and easier to just take everything out and install a new motherboard.
if what you want to do is flash the BIOS (basically updating the firmware inscribed into the chip), all you need to do is download and install the flash program from the mobo manufacturers website and download the newest BIOS instructions.
let me know which you do. ill help with any other questions.
Aug 15, 2008 | Intel Desktop Board D815EEA2 Motherboard
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
