Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Noisey fan my hampton bay fan is making a squeeking noise, is there a way to oil or grease the fan, or a place to do so.
    Sergeant:
    Champion:
  • 239 Answers
Use WD-40 w/ straw spray every hole you can find
Posted on Jan 04, 2009
My Hampton Bay ceiling fan has been making a sound - like a clicking noise - during every revolution of the fan, and at each of the 3 different speeds ever since it was installed.
Try a bit of chewing gum on each of the blades separately, it seems to be out of balance.By trying each individually and turning on each time you should find the imbalance.Cheers Michael....Australia
Jul 21, 2017 | Hampton Bay Dryers
Hampton Bay 52" Oil-rubbed bronze
If it's a Hampton Bay light kit, it should be no problem putting it on their fan.
Sep 04, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
Do I need to oil my ceiling fan ocasionally? I can't find a manual, so I don't know the model or serial #. I do have the orig order form from Home Depot, from '04. this fan is Hampton Bay 54" windward...
No the bearings are sealed, and not designed to lubricate. They can go bad, and if they do it is possible to remove the seals and re-oil/grease them. Sometimes this helps a little but not always. If you try to lubricate them without disassembling the fan, pulling the bearings, remove the seals, most likely whatever you try and squirt in their will just attract dirts and make things worse. getting to the bearings, usually means taking things apart that were not meant to come apart. So, the short answer is usually if they go bad the fan is shot. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 01, 2010 | Hampton Bay 04345 Cruiser Ceiling Fan
Hampton Bay fan bearing noise
its not the bearings sounds like you need to level the mount and that scraping it the fan blade mounting plate hitting the side of the 'case' that surrounds the motor assembly ive never heard of bearings in the motor going or needing lubrication other than what factory placed in them...remember Hampton Bay is the Yugo of electric appliances too
Aug 03, 2009 | Hampton Bay 24002 Ceiling Fan
Fan makes noise like it needs to be oiled.
No way to oil it. It is a sealed unit. Give it a small spray of WD40 that should relieve it. And will not hurt anything.
Jun 07, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay fan makes squeeking noise
If the fan is fairly new, remove it and return it to Home Depot. It is almost certainly something that has fallen down into the motor and is rubbing loudly enough to make a squeak as the fan runs faster.
The fan itself has sealed lubrication and you don't have to lubricate it.
Apr 07, 2009 | Hampton Bay 24750 Huntington III Ceiling...
I need an instruction manual to put my fan up. I
www.neonlightceilingfanstyles.co.cc/hampton-bay-ceiling-fan-instruction-manuals/ - 18 hours ago
Feb 24, 2009 | Hampton Bay 44 In. White Carousel II with...
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Oiling a ceiling fan
Robert,
you can submerge it into a bath tub filled with wd40 if you want to....provided the ONLY thing wrong is a squealing bushing...no shorted motor windings, right? It is hard to get oil into these bushings because of close tolerances and dust shields that hide the bushings. try it anyway...these motors are non-copper contacting magnetic induction driven, so near zero chance of spark-induced wd40 flame-up.
May 14, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
121 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
