Question about Brother DCP 130C All-In-One InkJet Printer
Brother printer/fax/scanner MFC-240 C
Pictures wont scan to file or email.....error message reads reinstall multifunctional suite, failed to start control center CC3-001-00001901.
should i uninstall and reload the program????
I need to scan and save multiple documents under one pdf file. how do i do this and save all under one file?
Posted on Jul 14, 2009
Brother mfc-j6510dw will not scan
This may help others with scanning issues:
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
I inherited a Brother MFC-440CN printer with no instructions. How can I scan a document from the printer to my email?
just scan it using the command from the computer ..after that you will find the job into the manager folder..of the scanner..from there you can send it directly ..or edit a little ..and copy into computer and attach to the email..or ..use the feature from the scanner's program to send it ..
make sure you set to scan picture cause scanners have a wizard that you can set to scan image (picture Jpeg ....) or PDF ..document ..
May 18, 2010 | Brother MultiFunction Center MFC-440CN...
How do i scan to my email? I have a brother product MFC-290c all in one with fax and i am trying ro scan to a picture to my email
May 14, 2010 | Brother MFC-290C Printer
My scanner/faxer won't scan for my mfc-490cw brother product. I always have to reset it and push 20 buttons so I don't remember how to do it. Can you help?
I have the same problem. It was working fine, then after not using it for a few weeks, all the sudden I couldn't scan. I'm hooked up wirelessly through my router. I can initiate a scan both from my PC and from the scanner itself, when initated from the scanner my PC responds and shows the progress bar, and the scanner actually scans. However for some reason no data is being sent back to the PC. And after a few minutes I get an error message saying that communication was lost (or something like that) error TW007. Yesterday I called into brother support and was on the phone for an hour and a half. they walked me through verifying connectivity, uninstalling and reinstalling the software and drivers, but to no avail. In the end we made no progress. I can print without a problem, and fax and photocopy. But for some reason it seems that the scanner is not transmitting the information back to the computer, even through the connection was established and the computer is waiting for the data.
Nov 29, 2009 | Brother MFC 490cw Color Inkjet...
I have a brother MFC 9440CN when I try to scan a document the error message comes up as not being connected to pc. The cable is definitly connected as the print option works fine. Can you help. Thank you.
Are you scanning from the PC, or are you scanning from the printer?
If the latter, the scanner is trying to send the document to a server software on the PC, which is probably not running; hence the "not connected" message.
Try acquiring a picture using Control Panel -> Scanners -> Acquire Image and see if it works. If it does, you must run (or reinstall) the Control Center software, and configure it as to where to store the Scan-to-File documents.
Nov 02, 2009 | Brother MFC-9440CN Laser Printer
Can't email scanned files.
hell csnevels you will need to uninstall the program and then reinstall the cd that came with the machine, if not you could download the cd from brother.com brother tech
Jan 17, 2009 | Brother MFC 240C All-In-One InkJet Printer
Control Center2 will not start - Error cc025
Had the same problem. The solution was: - uninstall the brother software with the application in the brother folder restart PC - reinstall mfl-pro Suite restart pc - install update to Controlcenter2 - install updated drivers
It then worked and I could finally scan over the network, for the first time ever!
Jan 14, 2009 | Brother MultiFunction Center MFC-440CN...
Printer Drive Problem
Please uninstall all drivers and software related to printer. Detach printer from computer connection.
Install drivers and software without the printer connected.
Restart computer and connect printer.
Thanks and Good Luck! =)
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
After reinstalling it wont scan or send faxes, the error comming up is error initializing in control center2. lack of registrer information. Install once again MFL-pro suite please help thanks C.
ununstall the brother software that came with the machine, then reinstall the cd brother mfpro sofwar, if you are still having a problem, let me know. brother tech
Dec 18, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother DCP 130C All-In-One InkJet Printer Logo
917 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
